Stereovox Καλώδια
The LSP-600 is a pure link to the music, a clear path through which both the delicate and the leviathan are reproduced with equal precision and articulation.
XHADOW millenio Spade Connectors
ISCoRS process and SVX-4947 solder formula
"Gossamer" dielectrics
Tri-Incident Dense Conductor Array
Lifetime Limited Transferable Warranty
The LSP-600 is precision-crafted from high-purity Silver and Mil-Spec silver-plated pure copper, in a Tri-Incident Dense Conductor Array of over 500 individual conductors, optimizing total density (resistance management) with individual strand density (for specialized skin-effect management).
Our special "Gossamer" air articulated PTFE insulators are concentrically wound in multiple layers for geometric precision and mechanical damping. Gossamer provides an extremely fast velocity of propagation, low capacitance, and low resonance quality for the entire length of the signal wire. The conductors are terminated using an intimately stressed contact resistance soldering process (ISCoRS), a clean and contact-reliable procedure that we believe is superior to traditional soldering methods. Our SVX-4947 formula is a low temperature eutectic (143 degrees Centigrade) silver-bearing solder, is among the most conductive solders in the world, and doesn't subject the conductors or the termination to the potential damage of the extreme heat that is typical of traditional soldering methods.
XHADOW millennio spade terminations have been custom-designed for the precise requirements of the SEI-600's special geometry and Stereovox's ISCoRS termination method, and are the finest and most precise connectors in the world.
The SEI-600 is a precision implement of revelation, an unobstructed conduit through which the truth of the music can travel freely.
XHADOW millenio RCA connectors
Two Discrete, helically-wound shields
ESC high-purity silver conductor
The SEI-600 is precision-crafted from high-purity Silver with our exclusive ESC (elliptical solid core) signal wire, applying our optimized aspect-ratio, creating a specialized skin-to-core profile for the signal to travel within.
The SEI-600's dual, discrete helically-wound shields behave as if they were a solid tube of metal, reducing signal leakage and creating a quiet and serene environment for the delicate signal to travel within. Together with layers of Gossamer between them, shields help to form a quasi constrained-layer arrangement for additional damping of vibration.
The signal conductor is terminated using our intimately stressed contact resistance soldering process (ISCoRS), a clean and reliable procedure that we believe is superior to traditional soldering methods. Our SVX-4947 formula is a low temperature eutectic (143 degrees Centigrade) silver-bearing solder, is among the most conductive solders in the world, and doesn't subject the signal wire or contact pin to the potential damage of the extreme heat that is typical of traditional soldering methods.
XHADOW millennio RCA connectors have been custom-designed for the precise requirements of the SEI-600's special geometry and Stereovox's ISCoRS termination method, and are the finest and most precise connectors in the world.
Από το site της εταιρείας.
περισσότερα:
http://www.stereovox.com/
  • loggeo
Elena-g
