Νέοι A/V ενισχυτές Onkyo, 3D ready, HDMI 1.4.
gkontoletas
trouble in my brain
Δύο νέους A/V ενισχυτές παρουσίασε η Onkyo, οι οποίοι είναι 3D ready, έχουν HDMI v1.4 και Audio Return Channel (ARC).
Επίσης αλληλεπιδρούν με τις τηλεοράσεις Sharp Aquos, Toshiba Regza και Panasonic Viera/Diga δίνοντας τη δυνατότητα πλήρους έλεγχου και των δύο συσκευών από ένα τηλεκοντρόλ.
TX-SA608
7x190W
3D ready
HDMI v1.4 with ARC
Audyssey 2EQ, Dynamic Volume, DSX
Τιμή: 580 ευρώ στην Ιαπωνία
TX-SA578
7x160W
3D ready
HDMI v1.4 with ARC
Τιμή: 490 ευρώ στην Ιαπωνία
http://www.jp.onkyo.com/news/newproducts/audio/txsa608_sa578/index.htm
gkontoletas
trouble in my brain
Απάντηση: Νέοι A/V ενισχυτές Onkyo, 3D ready, HDMI 1.4.
Η Onkyo ανακοίνωσε 3 νέα μοντέλα A/V 3Dready για το 2010.
Onkyo debuts Three Mid-Range THX-certified, 3D-compatible, Network Receivers with FLAC-compatible Audio Streaming and iPod/iPhone album art display
1st July 2010: Onkyo, the UK's No1 home cinema receiver maker, announces the release of three new mid- and upper mid-range network-enabled models for 2010: the TX-NR1008, TX-NR808, and TX-NR708. Each is THX® Select2 Plus™ certified and offers the latest processing and user-friendly features to support network audio streaming (with playback of FLAC (Free Lossless Audio Codec) music, iPhone®/iPod®-compatible USB input, multi-room set-ups and fully immersive 3D-capable home cinema with multi-dimensional surround sound to match.
Each of these models comes with seven of the latest HDMI® 1.4a connections, guaranteeing compatibility with the new 3D video formats that are promising to bring an exciting new dimension to movies and games in the home.
HDMI is also the conduit for full 1080p video upscaling of all video inputs, regardless of native resolution, via Faroudja's acclaimed DCDi Cinema™ technology, included on all three of the new Onkyo receiver models. DCDi Cinema works to remove 'jaggies' during the video signal deinterlacing process, resulting in smooth progressive scan video images.
Each of these network receivers includes a rear-panel Ethernet port that links it directly to the internet or to a home PC. Users can then enjoy superior fidelity from a wide range of audio file types including, for the first time, FLAC (Free Lossless Audio Codec) files, the open-source codec of choice for discerning audiophiles. Other supported formats include MP3, WMA, WMA Lossless, WAV, Ogg Vorbis, AAC, and LPCM. They can also access a range of different streaming Internet radio services provided by LastFM, vTuner, and Napster* (*availability of services depends on region.)..........
Full press release
TX-NR1008
ADVANCED FEATURES
  • THX® Select2 Plus™ Certified
  • HDMI® (Version 1.4a to Support 3D and Audio Return Channel) with Deep Color™, x.v.Color™, LipSync, Dolby® TrueHD, DTS-HD Master Audio™, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC
  • 7 HDMI Inputs (1 Front/6 Rear) and 2 Outputs
  • Audyssey DSX™ and Dolby® Pro Logic® IIz for New Surround Channels
  • ISF (Imaging Science Foundation) Video Calibration
  • Large-Size Transistors for High-Current Drive
  • Network Capability for Streaming Audio Files (MP3, WMA, WMA Lossless, FLAC, WAV, Ogg Vorbis, AAC, LPCM)
  • Internet Radio Connectivity (Last.fm, Napster, and vTuner)*
  • Certified with Windows® 7 and DLNA Version 1.5
  • Front-Panel USB Input for Memory Devices and iPhone/iPod Models (Enables Display of Album Artwork)
  • Firmware Updates via Ethernet and USB
  • Powered Zone 2/3 and Zone 2/3 Pre Outs for Distributed Audio Playback in Multiple Rooms
  • *Availability of services depends on region.
AMPLIFIER FEATURES
  • 180 W/Ch at 6 Ω, 1 kHz, 1 Channel Driven, IEC
  • WRAT (Wide Range Amplifier Technology)
  • Three-Stage Inverted Darlington Circuitry
  • H.C.P.S. (High Current Power Supply) Massive High Power Transformer
  • Linear Optimum Gain Volume Circuitry
PROCESSING FEATURES
  • Burr-Brown 192 kHz/24-Bit DACs (PCM1690 and PCM1789) for All Channels
  • Two 32-Bit Processing DSP Chips (DA830 and CS49834)
  • PLL Jitter-Cleaning Circuit Technology
  • Dolby® TrueHD, DTS-HD Master Audio™, Dolby® Digital Plus, DTS-HD High-Resolution Audio™ Decoding
  • HDMI Video Upscaling to 1080p with Faroudja DCDi Cinema™
  • 4 DSP Modes for Gaming: Rock, Sports, Action, and RPG
  • Music Optimizer™ for Compressed Digital Music Files
  • Direct Mode and Pure Audio Mode
  • A-Form Listening Mode Memory
  • Theater-Dimensional Virtual Surround Function
CONNECTION FEATURES
  • Universal Port for Single-Cable Connection of Optional Onkyo Dock for iPhone/iPod or DAB+ Radio Tuner
  • Component Video Switching (2 Inputs and 1 Output)
  • 4 S-Video Inputs and 2 Outputs
  • Analog RGB Video Input (D-sub, 15 pin) and Audio Input for PC
  • 6 Digital Inputs (3 Optical and 3 Coaxial)
  • 5 A/V Inputs (1 Front/4 Rear) and 1 Output
  • Color-Coded, 7.1 Multichannel Inputs
  • Video Output (Monitor)
  • 1 Audio Input
  • Phono Input
  • Color-Coded, 9.2 Multichannel Pre Outs
  • RS232 Port, IR (In/Out), and 12 V Trigger Outs (Zone 2/3)
  • Bi-Amping Capability
  • Color-Coded, Banana Plug-Compatible Speaker Posts
  • RIHD (Remote Interactive over HDMI) for System Control
OTHER FEATURES
  • Audyssey MultEQ® for Room Acoustic Correction
  • Audyssey Dynamic EQ® for Loudness Correction
  • Audyssey Dynamic Volume™
  • Overlaid Graphical On-Screen Display (OSD) via All Video Outputs
  • Crossover Adjustment (40/50/60/70/80/90/100/120/150/200 Hz)
  • A/V Sync Control Function (Up to 250 ms in 5 ms Steps)
  • 40 FM/AM Random Presets
  • RDS (PS/RT/PTY/TP)
  • Compatible with RI (Remote Interactive) Dock for iPod
  • Bi-Directional, Preprogrammed, and Customizable RI Remote Control with On-Screen Setup, Mode-Key LEDs, and Macro Presets for Four Activities
gkontoletas
trouble in my brain
TX-NR808
ADVANCED FEATURES
  • Powered Zone 2 and Zone 2/3 Pre-Outs for Distributed Audio Playback in Multiple Rooms
AMPLIFIER FEATURES
PROCESSING FEATURES
  • Burr-Brown 192 kHz/24-Bit DACs (PCM1690) for All Channels
CONNECTION FEATURES
  • 1 Audio Input
  • Phono Input
  • Color-Coded, 7.2 Multichannel Pre Outs
OTHER FEATURES
gkontoletas
trouble in my brain
TX-NR708
ADVANCED FEATURES
  • 7 HDMI Inputs (1 Front/6 Rear) and 1 Output
  • Network Capability for Streaming Audio Files (MP3, WMA, WMA Lossless, FLAC, WAV, Ogg Vorbis, AAC, and LPCM)
AMPLIFIER FEATURES
  • 170 W/Ch at 6 Ω, 1 kHz, 1 Channel Driven, IEC
PROCESSING FEATURES
CONNECTION FEATURES
  • Front-Panel Audio Input for Portable Devices
  • 5 Digital Inputs (2 Optical and 3 Coaxial)
  • 1 Audio Input
  • Phono Input
  • Powered Zone 2 and Zone 2 Line-Out for Distributed Audio Playback in Another Room
  • RS232 Port, IR (Input), and 12 V Trigger Out (Zone 2)
OTHER FEATURES
  • Overlaid Graphical On-Screen Display (OSD) via HDMI
  • Preprogrammed and Customizable RI Remote Control with On-Screen Setup, Mode-Key LEDs, and Macro Presets for Four Activities
Kαλά οι μεγάλοι 5008 5508που είναι?
Nelsy
Ιεράπετρα
καλησπερα σε ολους τους φιλους
μετα απο πολυ καιρο καταφερα και εγω με την σειρα μου και απεκτησα ενα μηχανακη Onkyo
η παραγκελια δοθηκε 21/05 στο γνωστο γερμανικο site οπου εγινε και η καταθεση μεσα ebanking transfer και ολα αρχισαν να πεγαινουνε ρολοι θα δειτε και την φωτο με την κινηση που μου εστειλε η ups
[/IMG]
η πρωτη εντυπωση οταν ηρθε ο courier και μου εφερε το δεμα με το στομα ανοικτο:121::121::121:
τα πολλα λογια ειναι περριτα οτι και να πουμε ειναι λιγα
πανο στον AV κουμποσαν ενα ps3 ενα egreat m31b ενας 800αρις και ολα σε μια W2000
απο θεμα ηχειον προστοπαρον εχω την σειρα της sony(Pascal)835
ειμαι παρα πολυ ευχαριστημενος με την επιλογη που εκανα
ειμαι ακομα στο σταδιο του setup δεν τα εχω βρει ακομα ολα τα κολπα του
εχουμε καιρο προστα μας
το δεμα ειναι εδω απο της 03/06 το σκ που μας περασε εκατσα και το συνδεσα
o ONKYO TX-SR608 μπορει να οδηγησει τα Crystal Audio THX-3D12 η ειναι μικρος γι αυτα τα ηχεια?μηπως ξερει κανεις ποτε ερχονται ελλαδα οι ενισχυτες με HDMI 1,4?
Re: Απάντηση: Νέοι A/V ενισχυτές Onkyo, 3D ready, HDMI 1.4.
Μπορεί,σε λογικά πλαίσια πάντα.Για πόσα τ.μ. χώρου μιλάμε;
Εντός του μήνα,αν δεν έχουν έρθει ήδη(τουλάχιστον οι Pionneer και Sony).
Στο παρον σπιτι καπου στα 45 τ.μ.Μαλλον θα περημενω λιγο ακομα απο το να προβω σε αγορα απο γερμανια.Καμια αλλη προταση υπαρχει για ενισχυτη για τα συγκεκριμενα ηχεια με HDMI 1,4?ευχαριστω για την απαντηση gstrifte...αν και περισοτερο μου αρεσουν οι pioneer ειναι αρκετα πιο ακριβοι απο τους ONKYO....
Αρκετά τα τετραγωνικά..Μάλλον θές κάτι δυνατότερο απ τον 608 για να καλυφθείς αν θες να παίζεις δυνατά και με την απαραίτητη επάρκεια ισχυός για τα δυναμικά.
Πάντως και με τον 608 είσαι καλυμένος όσο κινήσαι σε νορμάλ εντάσεις.
Re: Onkyo TX-SR608 AV Receiver Review
Pros
  • Good up-to-date feature set
  • 3D video compatible
  • Enjoyable movie performance
  • Quite powerful for the money
  • Easy to set-up
  • Cool and quiet-running
  • Good value for money
Cons
  • Doesn’t quite meet all expectations
  • Less assured with music playback
  • Doesn’t suffer poor sources
  • Works best with easy to drive speakers
  • Video processing adds little value
Όχι και τόσο καλό review απο το avforums.
Πηγή:http://www.avforums.com/review/Onkyo-TX-SR608-AV-Receiver-Review.html
stratos.april
