DIY Loudspeakers, Accuton Drivers, Digital (DSP) Active Crossover
Alex_Zapantis
Απάντηση: DIY Loudspeakers, Accuton Drivers, Digital (DSP) Active Crossover
Accuton Drivers
http://www.accuton.de/home/index.php
About us
The design of speaker drivers and then consequently loudspeaker boxes is the major part of our business and over the years we have driven this to some sort of perfection that attracts many of the leading speaker designers of the High-End world. Companies like:
Avalon Acoustics, USA
Ayon, Austria
Consensus Audio, Austria
Evolution Acoustics, USA
Gryphon, Denmark
Isophon, Germany
Kharma, Netherlands
Lindemann, Germany
Lumen White, Austria
Margules Audio, Mexico
Marten Design, Sweden
MSD, South Korea
surrountec, Germany
Tidal, Germany
Company history of Thiel & Partner GmbH
In the year 1984 the Backes & Muller production-engineer Bernhard Thiel invented a process to produce very thin sheets of extremely hard corundum (Al2O3), also known as saphire. This patented procedure allowed the manufacturing of very stiff, light weighted and highly damped loudspeaker calottes. This new and very hard material facilitates loudspeaker drivers with broader bandwith, lower distortion and a purer sound than ever before possible.
At first, these ceramic drivers were produced exclusively for new Backes & Muller products, but a few years later Bernhard Thiel stepped out of B&M and founded his own company, the original Thiel GmbH in Homburg, Germany. His loudspeaker units - only tweeters and midranges at this time - were distributed quickly in the audiophile world and gained a very high reputation for their sonic virtues. Very soon, these drivers were used in many of the - top of the line - high end loudspeaker boxes of today’s world.
Backes & Muller, still being the main customer for Bernhard Thiel, went out of business in the year 1992. This - of course - presented some major problems for the young Thiel GmbH. So Bernhard Thiel started looking for a partner to take care of the economical side of business. This partner was found in Adrian Bankewitz, at this time european distributor of Accuton products and long time friend of Bernhard Thiel. He bought the assets of the old Thiel GmbH and put together the production and distribution channels and the new Thiel & Partner GmbH of today was born. Since those early days, Accuton has experienced a continuous growth and expansion. Some of the milestones are:
1996 - design of the first bass units with ceramic dome
1999 - invention of the diamond tweeter membrane and patent application
2000 - Accuton becomes a registered trademark
2009 - design of the sandwich cone
Alex_Zapantis
Amarra Audio Interfaces
Digital-To-Analog and Analog-To-Digital converter!
The Amarra Model Four is the ultimate FireWire–based audio interface with amazing versatility at a very reasonable price. It provides an array of functions that allow you to listen to high-definition digital audio with unprecedented ultrafidelity.
Sonic Studio 304 FireWire Audio Interface
Features :
8 balanced analog inputs, 8 AES/EBU inputs, 8 balanced analog outputs
Supports 44.1, 48, 88.2, 96, 176.4 & 192 kHz sampling rates
Includes Sonic EQ and extended +DSP processing (over 100 plugins)
Fully supports Core Audio for all Mac OS X applications
Optional mic-pre's and high performance Power Supply (Q1, 2011)
Tight Integration with Amarra (Volume Control, Dim, Routing)
Sonic Studio 305 FireWire Audio Interface
All the features of the 304 plus 8 channels of Microphone Pre Amp
Plugins and Processing
Sonic EQ filter topologies include:
• 1st - 4th order fully Parametric filter with 5 interactive controls
• 1st - 4th order High & Low Shelving filter with 4 interactive controls
• RIAA Emphasis & DeEmphasis filters
• High & Low Bandpass filter with 4 interactive controls
• High & Low Bandstop filter with 4 interactive controls
• Digital DeEmphasis for AES/EBU 44.1 kHz
• Infinite Notch filter
• DC removal function
+DSP Advanced Plugins :
• Encode/Decode Mid/Side Processor
• 2x2, 3x3, 4x4, 5x5 & 6x6 Crosspoint Mix Matrixes
• 1 & 2 Channel Dynamics Processors
• 1 & 2 Channel, 6 & 12 Band Fully Parameteric EQs
• 1 & 2 Channel Dynamics Limiters
• 1 & 2 Channel EQ + Dynamics Processors with side chain
• TPDF & Hipass TPDF Redithering
• 2 Input Summing Node / 2 Input Difference Node
• 2 Input Sum & Difference Node / 2 Input Multiplier
• 1 & 2 Channel Delays
• Multitap Delays
• 1st Order Allpass Filter
• And many more...
Sonic Console
Sonic Console for Amarra
Custom Templates
Sonic EQ
Support Available (Yearly Amarra Support)
Manos58
εγχειρισμένη
Γιατί η Metric λέγεται Amarra ?:421:
Να ρωτήσω ποιός έφτιαξε τα εκπληκτικά αυτά ηχεία??
Δεν ξέρω πως παίζουν αλλά από εμφάνιση είναι "ψαρωτικά"!!
Στις φωτό που παραπέμπεις φαίνονται και κάποια άλλα. Τι είναι??
Manos58
εγχειρισμένη
Ένας Ουγγαρέζος Diyης.
Αναλυτικά πως φτιάχνονται.Χρειάζεται CNC 3D για να πετύχει η συνταγή.Και κόστισαν 9000 €.
Τα original πωλούνται #90.000 € #
Μάλλον συμφέρει θα έλεγα.
αυτα μαλλον παιζουν και καλυτερα αφου τα original θα ειναι με παθητικο κροσοβερ.
Μάνο απλά εκπληκτικά. Και μόνο να τα έχεις στο σαλόνι χωρίς να παίζουν!!
Αλήθεια εδώ υπάρχει κανείς με CNC 3D να ασχολείται με το hobby μας??
Manos58
εγχειρισμένη
Εκεί που έφτιαξες το πικάπ ?
Δεν ξέρω, θα τον ρωτήσω.
dapost
Rehdeko & Harbeth lover
Να ρωτήσω εγώ κάτι άσχετο: ξέρουμε αν στο απλό amarra που έρχεται με 4-band sonic EQ μπορεί να επεκταθεί με περισσότερες μπάντες και ξεχωριστή ρύθμιση left/right channel; Κάτι σαν το +dsp που αναφέρεται παραπάνω; Παρεμπιπτόντως, το sonic EQ είναι από τα λίγα minimum phase ψηφιακά EQ που θεωρούνται από πολλούς ως τα καλύτερα ηχητικά (καλύτερα από τα linear phase που είναι και τα περισσότερα που κυκλοφορούν.)
Car_Audio_Test
Η μαύρη επένδυση στο εμπρός τμήμα του όμορφου ηχείου κατασκευαστικά από τι υλικό είναι?
Manos58
εγχειρισμένη
:444:
Ακριβή κατασκευή και θέλει τρομερή ακρίβεια στο ταίριασμα.
Επίσης είναι απορίας άξιον πως κόλλησε τους καπλαμάδες στις κούρμπες στο επάνω μέρος.
Car_Audio_Test
Αν τους βάλεις σε νερό και μουλιάσουν? Εσύ είσαι πιο ειδικός λόγω δουλειάς.
Manos58
εγχειρισμένη
Ευκαπτοι γίνονται με ατμό που ανεβάζει την υγρασία του ξύλου και το κάνει εύπλαστο.
Το ζήτημα είναι με τι κόλλα και πως το πρεσάρεις μετά.Αν βραχεί αποκλείονται βενζινόκολλες
Μάνο έχεις δίκιο. Ρώτησα τον Γιώργο τον Δάρα, που έφτιαξε το πικάπ μου και όντως το δικό του είναι CNC 3D.
Οπότε όποιος ενδιαφέρεται μπορεί να απευθυνθεί σε αυτόν.
Manos58
εγχειρισμένη
Αφού πρώτα περάσει από την τράπεζα του με βαλιτσάκι:126::110:
panaplio
