For No freezing S*K*Y U*K* - I*T .
Menu - System Settings - OSD Style - Instant Delay Level 2 ....
Then while watching a channel ,press yellow button .
via
13*E
12245 H 27500 MEZZO
16*E
12706 V 3702 Sic Int.
9*E
12149 V 27500 Ant1 Europe
cw
ORF - 19*E
11243 H 22000 ORF SPORT+, ATV2
11303 H 22000 ORF1 HD, ORF2 HD
12663 H 22000 ORF 3
12692 H 22000 ORF1/ORF2/ATV
Austria Sat - 19*E
10921 H 22000 AXN Action, sportdigital
11739 V 27500 MTV Hits, MTV Dance, VH1, MTV ROCKS
11973 V 27500 MTV Music
12051 V 27500 PULS 4 Austria
12188 H 27500 RTL Living
12344 H 27500 Hustler TV, Animax, Dorcel TV, Planet
12545 H 22000 Sat.1 Comedy, kabel eins clas
CSLink-SkyLink - 23.5*E
11798 H 27500 Nova HD, CT sport HD, Retro Music TV
11836 H 27500 TV JOJ, JOJ PLUS, Markiza, DOMA, STV1, STV2,DAJTO
11895 V 27500 TV Barrandov
11934 V 27500 CT HD
11973 V 27500 FANDA
12070 H 27500 Prima COOL,Nova, Nova Cinema, Prima Love
12525 V 27500 CT 1 JM, Prima family, CT1, CT2, CT1 SM, CT sport
ird
Bulsatcom - 39*E
12524 H 30000 Planeta TV, Nova TV, Kino Nova, Diema
12565 H 30000 TV Evropa, CN, TCM, FOX
12688 H 30000 Diema Family, National Geogra, NOVAsport, AXN, FOX Life, FOX Crime
Biss keys
12548 H 13960 Digea 3*E
12568 H13960 Digea 3*E
10730 H 27500 Fox Sports HD 30*W
11387 V 30000 NBA TV HD 10*E
11919 V 27500 Eurofootball Gonki 9*E
11923 V 27500 OPAP TV 9*E
10890 V 27500 TVI Internacional 30*W
12611 H 9259 MGM 10*E
11770 H 27500 1+1 Int. 5*E
12601 V 2960 1.tvGeorgia 42*E
12596 V 3700 Rustavi 2 42*E
12526 H 4444 2M Nat. HD 3*E
11495 V 44100 BBC Package 27,5*W
12165 H 27500 Star World Middle East 52,5*E
12168 H 27500 STAR Movie HD 52,5*E
11629 H 2400 TV 1 Bosnia 16*E
11059 H 23700 ENTV 5*W
12674 H 20255 ENTV 22*W
11390 H 27500 XSPORT 4*W
12130 V 27500 NLO TV 5*E
12645 H 3255 Earth TV 15*W
11766H 27500 TET 5*E
12284 V 27500 INTER+ 5*E
11044 V 44950 Disney 53*E
11428 H 30000 Fox Crime Africa 12,5*W
11424 H 30000 Mediapro 12,5*W
12322 V 27500 MBC USA 7*W
11911 H 5480 Sinema TV Ask HD 42*E
11915 H 5480 Sinema TV Aksyon HD 42*E
11169 H 20400 Idman Azerbaycan 46*E
Spiderbox/Smartbox HD6000 Channel Editor 1st Version
IMPORTANT !!!
1)After saving your channel list in usb stick in receiver and transfer it to your PC ,you have to add in archive .ssu extension so it can be read from channel editor .
2)After editing your channel list in channel editor and download it in your receiver ,then you have to check the motor settings : lnb type ,usals,diseqc1.2 etc. to be the correct .
3)After using Internet Sat/TP database option in channel editor and download it in your receiver ,then you have to check the motor settings : lnb type, usals,diseqc1.2 etc. to be the correct .
Need your feedback !!!
We will be back with new updates !!!
Αυτη η λιστα ειναι αρκετα καλα ανανεωμενη .
Εχει τις νεες συχνοτητες απο Sky 28,2*Ε * & MEO 30*W αλλα και απο τους αλλους δορυφορους .
Με λιστες αγαπημενων .
Προσεχως θα ανεβασω την νεα βερσιον του καλυτερου channel editor για δεκτη με την επιλογη να κατεβαζει καναλια απο το kingofsat στη μορφη αρχειου του δεκτη .
Οπως επισης και νεο patch .
Fav1 --> for your own use
Fav2 --> Polish
Fav3 --> Italian
Fav4 --> Spanish
Fav5 --> German
Fav6 --> French
Fav7 --> English
Fav8 --> Portuguese
NEW 6000 Channel Editor 1.0.0.1
02/11/13 - Version 1.0.0.1
1 - Fixed bug where opening a file would crash the program.
2 - Fixed bug with Drag/Drop re-arranging of channels.
3 - Removed Internet Sat/TP Download from the "New" menu.
4 - Added NEW Internet Database Download, Includes Sats, TP's & TV/Feed/Radio/Data Channels.
5 - Added "About" popup.
6 - Added "Change Log" inside the About popup.
7 - Added Right Click option for adding your selected channels to favourites.
8 - Fixed bug where the number of Favourites wouldn't update correctly.
9 - Added "Name ID", "Provider" & "Category" to the Channels Table.
10 - Added new Sorting options.
11 - Added Save/Import Favourites in the TOOLS Menu.
12 - Added "Hide Column" button to maximise available space in the channels table.
13 - If you choose to sort channels through the Tool Menu, the selected sort is now highlighted in BOLD.
14 - Changed the name of the "Default Sort Order" to "Custom Sort Order"
15 - Added Sorting options to the Channel Table "Right Click"
16 - Added option to Save the last Sort Order(If this is TRUE, then after a Internet Download, the channels will automatically sort to your last used sort order)
17 - Changed the way the settings are saved. For future updates, all you need to do is overwrite the exe file.
18 - Removed pinging www.google.com to check for a internet connection(You must make sure you are connected to the Internet to use the "Download Internet Database" function.
How to install
Extract the files and run 6000 Channel Editor.exe
If you get this error:
#.NET Framework Initialization Error #
#To run this application, you must first install one of the following version of the .NET Framework.#
1 - Please use Windows Media Player to view the Quick Start Guide.wmv file
2 - This version has been tested with the latest Patch(HD6000_09_06.ssu).
3 - If you use the "Internet Download" you must Re-Enable your Satellites, input your Motor Settings and De-Select Satellite Number 53, 58 & 60 as the program uses the Factory Default settings whilst creating the SSU file(This is a known problem and we are working to solve it).
Νομιζω οτι η δυνατοτητα να κατεβαζει καναλια απο το kingofsat (με ολες τις αλλαγες) και να τις προσαρμοζει σε αρχειο καταλληλο για τον δεκτη ειναι μοναδικη !!!
First Save your channel list
Put wireless (wifi) off - Your lines off
Download patch
Factory settings
IMPROVEMENTS :
1.IPTV function
Menu-IPTV --> pressing 'Default' (blue button),default IPTV channels appearing.
Edit --> Delete --> Delete one , Delete all
For going back --> press exit button
For going massive channels down or up ,use arrow buttons (next RECALL & GOTO buttons).
2.RSS function
3.3G dongle support with SIM card
4.Youtube fix
Pressing blue button --> resolution, then up or down button so you can change to higher resolution.
Instructions for IPTV function, user creating his IPTV channel list and add in receiver :
a)Make IPTV.ipt file using wordpad (attached file)
