* Πατάμε Enter.powershell -ExecutionPolicy Unrestricted Add-AppxPackage -DisableDevelopmentMode -Register $Env:SystemRoot\WinStore\AppxManifest.xml
* Ξανά Enter και είμαστε έτοιμοι. Αν δουλέψει, δούλεψε...start "" "ms-windows-store:"
Power buy?Λέγε τώρα τι να κάνουμε γιατί έφτιαξα κι ένα boot drive και δε δούλεψε. Θα πάρω MAC.
This update package fixes the issues that are documented in the following Microsoft Knowledge Base (KB) articles:
- 2870467 Memory leak in Oleaut32.dll on a Windows 7 SP1, Windows Server 2008 R2 SP1, Windows 8, Windows Server 2012, Windows 8.1 or Windows Server 2012 R2-based COM server
- 2891804 Files or folders are removed unexpectedly when you perform a cut-and-paste operation on a Windows FTP client that is connected to an FTP site
- 2897602 FIX: TCP connections that use ephemeral loopback addresses are dropped suddenly in Windows
- 2910642 Video playback in Windows Media Player stutters or stops in Windows 8.1 or Windows RT 8.1
- 2908931 Camera image orientation on viewfinder of display screens are rotated 90 degree on a Windows 8.1-based Portrait-First device
- 2911039 Scheduled task in Windows restarts unexpectedly after computer restarts
- 2912225 ADAC crashes when you try to use the global search in Windows 8.1 or Windows Server 2012 R2
- 2913016 Error message when you try to print some XPS files by using XPS Viewer in Windows 8.1 or Windows Server 2012 R2
- 2913218 English IME is set as the default IME instead of a localized IME after OOBE wizard in Windows RT 8.1, Windows 8.1, or Windows Server 2012 R2
- 2913312 Ctrl+Alt+Del keyboard shortcut is not displayed on the logon screen to tell the user how to reach the credential prompt in Windows RT 8.1, Windows 8.1, or Windows Server 2012 R2
- 2913317 Autocorrection feature does not remember user decisions in Windows 8.1
- 2913765 Certain cameras cannot be used as removable drives in Windows RT 8.1, Windows 8.1, or Windows Server 2012 R2
- 2914002 Update fixes several Windows Store app-related issues
- 2914011 Update resolves a Windows Store app issue and a printer issue
- 2914180 You cannot connect to FTP servers through a Wi-Fi hot spot
- 2914211 Internet Explorer tab freezes when it makes a COM call to a suspended tab
- 2914217 Duplicate files in a symbolic link folder after you upgrade from Windows 8 to Windows 8.1
- 2914219 USB storage device does not work correctly in Windows 8.1 and in Windows Server 2012 R2
Οι τελευταίες πληροφορίες αναφέρουν ότι τι κόλπο με την registry δεν λειτουργεί πλέον, στο παρακάτω link θα βρείτε κι άλλους τρόπους, με προσοχή όμωςIn regedit, navigate to “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\” and create a new key called “SHWindowsPoolS14″, now reboot your PC and check for new updates. You should see “Update for Windows 8.1 for x64-based Systems (KB2919442) – (S14 Prerequisite v01.0008)“,
Λογικό δεν είναι;Άρχισαν να ξυπνάνε...
Τι να το κάνουμε;επιστρέφει το start button...
Καλά ρε τζόβενο, δεν είναι όλοι σαν κι εσένα.Τι να το κάνουμε;
Μια χαρά είναι χωρίς και μάλιστα πιο γρήγορα βρίσκεις τα προγράμματα σου!
