Chromecast Audio
m1ts0s
News poster
What is Chromecast Audio?
Chromecast Audio is a small device that plugs into your speaker for streaming music through WiFi.
Once set up, simply use your iPhone, iPad, Android phone and tablet, Mac and Windows laptop, or Chromebook to cast your favorite tunes to the best speakers in the house.
SPEAKER INPUTS SUPPORTED:
RCA
3.5mm
Optical
Easily cast music, without the hassle of pairing
Tap the Cast button from music apps to hear the music instantly on your speakers. Search, play, pause, queue songs and turn up the volume right from your phone—anywhere in the house.
Listen to your favorites, anytime
Enjoy over 30 million songs from music services like Pandora, Google Play Music, iHeartRadio and Rdio. We're constantly adding new apps, so there's no end to the music, radio stations and podcasts you can enjoy.
Jam out to your music without interruption
Casting won’t drain your battery or get in the way of other activities. Answer a call, surf the web, even leave the room—all without interrupting the tunes.
Cast any audio from your Android phone or your laptop
If it’s online, you can cast it. Hear anything playing on your Android phone or tablet on your speaker, or use your laptop to cast music and audio streaming websites from the Chrome browser.
For $35
Υποστηρίζει και Spotify
http://www.google.com/chromecast/speakers/
http://www.google.com/chromecast/learn-speakers/
m1ts0s
News poster
Google Announces High-Res Support for Chromecast Audio
'Introducing Hi-Res audio support
Close your eyes and imagine the musician is playing in the room. Today we’re rolling out high-resolution audio support, which gives you even higher quality music playback using Chromecast Audio. With support of up to 96KHz/24bit lossless audio playback, you can enjoy higher-than-CD-quality audio on your existing high fidelity audio equipment.'
Οπότε λέτε με 35 € περίπου να έχουμε ένα καλό dacaki για ασύρματη μεταφορά. Το What Hifi που το δοκίμασε αναφέρει πως η ποιότητα ήχου είναι σαν να συνδέεις απευθείας το κινητό με καλώδιο RCA στον εκάστοτε ενισχυτή....
Ψάχνοντας για μια συσκευή από την οποία θα ακούω μουσική στα γρήγορα στον/α ενισχυτή/ηχεία, χωρίς καλώδια, χωρίς να ανοίγω pc κλπ., έχω πέσει πάνω στο Chromecast audio με την αναπαραγωγή μέσω WiFi, και στο TP-Link HA100 με αναπαραγωγή μέσω Bluetooth.
Το Chromecast audio αναλύεται παραπάνω, το TP-Link HA100 στο παρακάτω λινκ.
http://www.tp-link.com/en/products/details/cat-5089_HA100.html
Έχει δοκιμάσει κάποιος μια τέτοια συσκευή, να μας αναλύσει την ποιότητα ήχου κι αν αξίζει η αγορά της;
Ευχαριστώ.
Φαντάζομαι αναφέρεσαι στο Chromecast. Κάνοντας μια αναζήτηση είδα πως λόγω streaming μέσω WiFi είναι καλύτερο του Bluetooth.
Από Ελλάδα δεν υπάρχει πουθενά όμως. Έχετε λινκ από πού το αγοράζουμε;
Πως και δεν εχουμε ξαναπιασει αυτο το θεμα? μηπως το εχουμε κανει καπου αλλου και μου ξεφυγε? Με αυτα που κανει ουσιαστικα,αχρηστευει το bluetooth (ok θελει δικτυο wifi),ενω η ψηφιακη εξοδος και η δυνατοτητα να βγαλει απο εκει σημα 24/96 και να στο στειλει σε καποιο dac,το κανει πολυ ενδιαφερον. Απο οτι ειδα υποστηριζει αρκετες εφαρμογες ηχου για andoid (tune in,rocket player,spotife και βεβαια youtube),που καλυπτουν πληρως τον μεσο χρηστη. Απλα μου κανει εντυπωση που σχεδον ενα χρονο μετα δεν πωλειται στις γνωστες αλυσιδες,παρα μονο σε μικρομαγαζα (δικτυακα).Το εχει καποιος να μας πει εντυπωσεις?
http://www.e-shop.gr/google-chromecast-audio-p-PER.706561
http://www.pc1.gr/showitem.php?ID=240009318
http://bestdeals.gr/eikona-hxos/tv/tuners/google-chromecast-audio-black/
To chromecast 2 εχουν μονο οι μεγαλες αλυσιδες ετοιμοπραδοτο Τασο.Περασα και ρωτησα αν εχουν το Αudio.
To οτι βγαζει σημα 24/96 και μπορω να το ριξω πανω στο dac του Denon dra-f 109 οπου εχω και το βασικο οτι εχει ιντερνετ ραδιο,με φερνει πολυ κοντα στην αγορα του απο Ελλαδα συντομα!
http://www.kotsovolos.gr/site/compu...romecast-2-hdmi-streaming-media?cmicc=skroutz
http://www.public.gr/product/tileor...a-streamer-google-chromecast-2/prod7850773pp/
Κοιταξα media markt και εχει μονο το chromecast 2 (video) οπως λες και εσυ (δεν ξερω γιατι σνομπαρουν το audio οι μεγαλες αλυσιδες) ,ενω και το skroutz δεν εβγαλε παρα δικτυακα καταστηματα (αυτα που αναφερεις). Οσο για το youtube,εννοω οτι μεταφερει τον ηχο,σε μια παρουσιαση του στο youtube το ανεφεραν.Ετσι και αλλιως ομως με tune in,spotify και εναν music player,ειμαστε πληρως καλυμμενοι.
Τελος παντων,νομιζω το βασικο πλεονεκτημα του ειναι οτι εχει ψηφιακη εξοδο ,γιατι ολα αυτα απο την αναλογικη εξοδο,δεν βγαζουν καλο ηχο (widaptor και widac για να αναφερθω σε συσκευες κοντινες σε λειτουργια που εχουμε συζητησει.....το widac εχει οπτικη ψηφιακη εξοδο αλλα μεχρι 16/48,αλλα εχει τα θεματακια του με τις συχνες αποσυνδεσεις κλπ).
Λοιπον........
Μολις ηρθε στα χερια μου. Συνδεθηκε στην optical του ενισχυτη και εκανα τις αρχικες ρυθμισεις.
Αυτη την στιγμη παιζει αψογα απο tunein. Aυτο που δεν εχω καταλαβει πως το βλεπει ο υπολογιστης ωστε να παιξω απο foobar η jriver.
και κατι οχι τοσο σχετικο.....μολις ανακαλυψα οτι εβγαλαν και εφαρμογη foobar για android.Μεχρι τωρα υπηρχαν εφαρμογες για ελεγχο του foobar στον υπολογιστη μεσα απο smartphone-tablet.
Δεν βγαζω ακρη μεχρι τωρα με οσα εχω διαβασει,και δεν εχει συζητηθει το θεμα πολυ. Εχω την εντυπωση οτι δεν συνεργαζεται και ανησυχω.....
Έμμεσος τρόπος:
Μπορείς μέσω του dlna server (plugin) του foobar (ή και άλλου dlna server, π.χ. plex, twonky) να κάνεις διαθέσιμους τους φακέλους με τα μουσικά αρχεία που έχεις και μετά να χρησιμοποιήσεις το Bubbleupnp για να κάνεις streaming των μουσικών αρχείων στο chromecast audio.
Ο Γιαννης θελει να στειλει σημα απο τον υπολογιστη με το foobar αμεσα,οπως πχ γινεται με ενα widac ή widaptor (απλα αναφερω γνωστες συσκευουλες),αν και με αυτες εχουμε υποβαθμιση του σηματος σε επιπεδο 16/48. Το chromecast audio,μπορει να βγαλει απο την ψηφιακη εξοδο σημα μεχρι 24/96,αλλα συνεργαζεται μονο με συσγκεκριμενες android εφαρμογες.
το καταλαβαίνω, αλλά υπάρχουν κάποια πλεονεκτήματα του άμεσου τρόπου έναντι του τρόπου που ανέφερα;
Παρεμπιπτόντως βρήκα ένα link που αναφέρει ένα πρόγραμμα (chromecast audio stream) που περνάει όλους τους ήχους του υπολογιστή στο chromecast. Δεν το έχω δοκιμάσει, οπότε με επιφύλαξη:
http://lifehacker.com/how-to-send-your-computers-audio-to-a-chromecast-1750297581
fchristos
