Marantz sr6006 7.2 av receiver
hamurabi
Καλησπέρα παιδιά.πωλειται ο ενισχυτής του τίτλου, άριστης ποιότητας ήχος,πάρα πολλές δυνατότητες, δίνεται καθαρά λόγω αναβάθμισης σε 4Κ.
Είναι σε άριστη κατασταση λειτουργικά κ εξωτερικά,θα δωθεί με τα καλώδια του και το μικρόφωνο ισοστάθμισης,είναι αγορασμενο από Ελλάδα στα 1.100 ευρώ.
Η τιμή που θα δωθεί είναι 390 ευρώ.
Review:
https://www.soundandvision.com/content/marantz-sr6006-av-receiver
Χαρακτηριστικά:
Power and processing:
  • 7-channel amplifier
  • 110 watts per channel into 8 ohms (20-20,000 Hz) at 0.08% THD, with 2 channels driven
  • individual image adjustments for each video source
  • dual PLL anti-jitter circuit for cleaner picture from all sources
  • Dolby® TrueHD, DTS-HD™ Master Audio, Dolby® Digital Plus, DTS-HD™ High Resolution Audio, Dolby® Digital EX, DTS-ES™, Pro Logic® IIx, Pro Logic® IIz, SRS Circle Surround II, and DTS Neo:6 decoding
  • Audyssey Laboratories' MultEQ® XT Pro enables eight-point user auto setup and room calibration and professional sixteen point calibration (microphone included)
  • Audyssey Dynamic Volume mode to keep listening levels steady
  • Audyssey Dynamic EQ™ for fuller sound at lower listening levels
  • M-DAX (Marantz Dynamic Audio eXpander) for better sound with compressed music sources
Multi-room Audio:
  • three-room/three-source output
  • powered and line-level stereo audio output for 2nd room
  • line-level stereo audio output for 3rd room
  • only analog sources can be played in the 2nd and 3rd rooms
Digital Music Options:
  • listen to music from iPod®, iPhone®, or other portable music player through the front-panel USB input
  • DLNA certified to ensure optimal compatibility with other network-enabled equipment
  • Internet streaming capabilities for Internet radio, PANDORA® Internet radio, Rhapsody® and more (may require registration and subscription fees)
  • Bluetooth-ready with added Marantz RX101 adapter
Audio Performance Features:
  • high-current amplifier design
  • Pure Direct mode switches off all unused circuitry for the cleanest possible sound
  • back surround speaker channels re-assignable for bi-amping front left and right speakers
  • 192kHz/24-bit digital-to-analog converters for all channels
Connections:
  • 1080p-compatible HDMI digital video switching (7 in, 2 out)
    • second HDMI output will run identical program to first to connect to two HDTVs or a TV and a projector
  • analog-to-HDMI video upconversion (up to 1080p)
  • HDMI version 1.4a with support for 3D video, Audio Return Channel, Deep Color, x.v.Color, SACD, auto lip-sync, and HDMI-CEC
  • component video switching (2 in, 1 out)
  • digital audio inputs: 2 optical, 2 coaxial
  • 8 audio/video inputs, including:
    • 1 front-panel input with composite
    • 4 rear-panel inputs with composite video
  • 2 audio-only inputs including a phono input for a turntable
  • dual line-level outputs for powered subwoofers
  • phono input to connect turntable
  • 7.1-channel analog audio preamp input
  • 7.2-channel analog audio preamp output for connecting an amplifier
  • front-panel USB port for audio playback from compatible iPods, USB flash drives, hard disk drives, and portable MP3 music players
  • RS-232C port for automated control systems
  • detachable power cord
  • direct IR flasher input, and 12V DC trigger out
  • 2 sets of main speaker outputs
General Features:
  • free Marantz remote app lets you use your iPod touch®, iPhone® or Android™ device as a Wi-F remote
  • on-screen display for easier system setup and operation
  • graphic user interface via HDMI
  • first-time setup wizard
  • multibrand remote
  • 17-3/8"W x 6-5/16H" x 15-5/16"D
  • weight: 26 lbs.
hamurabi
Νέα τιμή 310 ευρώ. Δεν πάει πιο κάτω η τιμή ,οποίος προλαβει προλαβε!
Υ.σ. ελπίζω να έπεσα μέσα στο 10% μείωσης αυτή τη φορα
Πακεταρισμενος στο κουτί, χειρηστιριο, μικρόφωνο ρύθμισης,κεραια ραδιο,όλα στις συσκευασίες τους αναμένουν τον επόμενο ιδιοκτήτη.
  • Like
Reactions: PPG
Katerinanota
