KEF Reference 207/2 loudspeaker
Κώστας Φ.
"The Reference 207/2
Other than the absence of the supertweeter pod, the 207/2 looks identical to its predecessor. A gloss-finished, cast-aluminum pod that carries the new Uni-Q drive-unit is mounted atop a wood-veneered cabinet with an elliptical plan section and complex internal bracing to minimize cabinet resonances. This handsome speaker manages to conceal its considerable bulk.
As before, a 10" pulp-cone lower-midrange driver, mounted in its own subenclosure, covers the one and a half octaves where instruments and voices have their fundamental energy (120–350Hz). It hands over below 120Hz to a pair of 10" fiber-reinforced paper-cone woofers, these individually reflex-loaded with two large, flared ports each more than 4" in diameter. One port is at the base of the front baffle; the other is on top, firing upward behind the Uni-Q pod. (With a radiating diameter so much smaller than the wavelengths of the sound it produces, the port is omnidirectional—it doesn't matter which way it points.) The lower-midrange unit has a stationary, chromium-plated phase plug on the end of its pole-piece; the woofers have conventional dustcaps. All three lower-frequency units use a pair of shorting Faraday rings on their voice-coil formers to reduce magnetically induced distortion; the woofers use a long coil mounted in a short gap to give constant drive force regardless of cone position, while the lower-midrange unit, with its reduced need for large cone excursions, has a short-coil/long-gap motor.
The new 1" titanium-dome tweeter in the 207/2 uses a vented pole-piece and is said to operate pistonically to a much higher frequency than in the original 207, eliminating the need for a separate supertweeter.
As in the 207, the 207/2's crossover features symmetrical 24dB/octave slopes, and electrical connection is via three pairs of plastic-covered binding posts at the speaker's rear. Short heavy-gauge jumpers, terminated with a spade at one end and a 4mm plug at the other, are supplied; I used them for all my auditioning. Two shorting plugs are also supplied; these are used to fine-tune the speaker's bass and treble balances by plugging in none, one, two, or all three into three sockets above the binding posts. By removing the plug from the bass socket, the low-frequency level can be shelved down by a couple of dB, to compensate for boundary loading if the speakers must be used close to walls. I auditioned the 207/2s with the shorting plugs set for free-space operation; ie, maximum bass. Even so, the speakers didn't boom. The other two sockets/plugs allow the entire treble region to be adjusted up by 0.75dB, or down by 0.75dB or 1.5dB. I did most of my listening (and all the measuring) with the treble set to flat, which worked best with rock recordings, but found that raising the treble by 0.75dB added some air to the sound of naturally miked classical recordings. I used the speakers without their grilles, but found very little difference with them on.
Summing Up
While spaces remain in my heart for the Sonus Faber Amati homage, the mbl 111B, the Dynaudio Confidence C4, the original Revel Ultima Studio, and the Wilson Audio Sophia, I must say that the Series 2 revision of KEF's Reference 207, the 207/2, is overall the best-sounding full-range speaker I have used in my current listening room. To all intents and purposes, it is without flaw. The lows are extended and well defined, the midrange is pure, the treble is free of grain and naturally balanced, the dynamics are awesome, and the stereo imaging is accurate and stable. The 207/2 simply defines neutrality, but without losing sight of the musical message. $20,000 is still a lot of money, but for a pair of speakers of this caliber, it's tempting to declare the big KEF a bargain, considering that you can pay five times as much for speakers that sound only as good."
-- John Atkinson
"Taken overall, KEF's Reference 207/2 offers superb measured performance. This is a speaker for which no excuses need be made. That it sounds as good as it does is no mystery." -- John Atkinson
Full Review: Stereophile.com
Κώστας Φ.
Χμμμ, νόμιζα παίζουν γύρω στα 15 στην πιάτσα...
Και ήμουν έτοιμος να σου πω για power buy! :happy_9:
melina
Cargo 200
Γιατί το αναφέρει ως full-range ενώ από ότι κατάλαβα έχει διάφορα μεγάφωνα που τα παντρεύει με crossover.
Ο όρος full-range δεν αναφέρεται σε υλοποιήσεις ενός δρόμου?
melina
Cargo 200
μμμ μάλιστα.
Και αυτά που πάνε και παραπάνω πως λέγονται over range?
thanks
Κώστας Φ.
Άλλο full-range ηχείο, άλλο full-range μεγάφωνο.
Τα ηχεία με ένα full-range μεγάφωνο κάθε άλλο παρά full-range μπορούν να χαρακτηριστούν.
Εχμ... Full-range. :happy_8:
Full range στις συχνοτητες που ακουει το ανθρωπινο αυτι (20Hz-20KHz). Η μαλλον οσοι ειμαστε νεοι και ακουμε τοσο......μπουχαχαχα
Παιδιά όταν ο ποιητής λέει full range εννοεί ηχείο 'πλήρους φάσματος'...Ότι δηλ. αποδίδει όλο το φάσμα όχι μόνο των συχνοτήτων που ακούμε(20-20) αλλά όλο το φάσμα που μπορούν να αποδώσουν τα υπεραναλυτικά σημερινά συστήματα(vinyl disk / sacd / hd audio)...Ούτως άλλως τε η KEF, μια από τις κορυφαίες εταιρίες του χώρου (που δυστυχώς την επισκίασαν με το marketing και διάφορες αλλοπρόσαλλες κατασκευαστικές μεθόδους και φιλοσοφίες άλλες πιο μοντέρνες εταιρίες) ΠΟΤΕ δεν ασχολήθηκε με μονόδρομες κατασκευές, κόρνες, ντουντούκες κλπ...
Όσον αφορά τα 207/2 τώρα σαν 100% χειροποίητα Εγγλέζικα ηχεία με τέτοιο φινίρισμα, σχεδίαση, τεχνολογία και ηχητική απόδοση νομίζω πως τα 15000 που ζητά είναι τιμιώτατα...
Gebreselassie
Μαύρος!
Ότι δηλ. αποδίδει όλο το φάσμα όχι μόνο των συχνοτήτων που ακούμε(20-20) αλλά όλο το φάσμα που μπορούν να αποδώσουν τα υπεραναλυτικά σημερινά συστήματα(vinyl disk:131: / sacd / hd audio)...
Ποιός ήρθε? :121:
Μάλλον θα εννοάει το δίσκο σερβιρίσματος της κ. Μελίδου. Υψηλής ανάλυσης, πάνω από 45 κεφτεδάκια ανά τετρ. εκατοστό.
Koυφοι, εμ σε τετοιες σταθμες που ακουτε εχετε χασει το αισθητηριο της ακοης ανω των εικοσι χιλιαδων οχι λευγων απο ταλλα.Ετσι που νακουσετε την διαφορα. Ερωτευτειτε βρε καμμια γκομενα να δειτε την διαφορα στο συναισθημα μεταξυ βινυλιου και ψηφιλας αλλα κανονικη οχι ιντερνετικη να την πιανετε στα χερια και να την χαιρεστε.
Τι να καταλαβεις βρε απο κεφτεδακια μικροτερα του 0,02 εκατοστων τσαμπα το αλευρωμα και το λαδι στο τηγανι. Φαε εκει ενα κεφτε μια χουφτα να γεμισει το στομα σου.
Την κυρια Μ. δεν την ξερω αλλα χωρις να θελω να την θιξω πρεπει να ειναι πολυ μικροσκοπικη για να φτιαχνει τοσο μικρα κεφτεδακια. Ο Ποντικομικρουλης πρεπει να της ριχνει τρια κεφαλια.
Ακου 45 κεφτεδακια ανα τ.ε. Ειναι τουλαχιστον οικολογα. Με ενα αμπελοφυλλο φτιαχνει χιλιους ντολμαδες.
Παντως αν καταλαβα καλα,
Τιμη καταλογου Ελλαδας (ή Ευρωπης): 20.000 ευρα
Τιμη καταλογου ΗΠΑ: 20.000 δολλαρια (ή 13.333 ευρά)
γκρρρρρ......:101:
Βασιλης
Ποιός ήρθε? :121:
Αυτός...
http://www.stereophile.com/features/282/index1.html
(Διαβάστε το όλο αν έχετε όρεξη...αν και στο τέλος μάλλον θα σας κοπεί....)
Finally, it gives me a new respect for the venerable analog medium: Many of the recordings I looked at that turned out to have significant ultrasonic content were originally recorded on analog tape.John Atkinson
Gebreselassie
Μαύρος!
Έτσι για να ξέρουμε τι ακούμε δηλαδή ε? :126:
But it is also true that LPs have higher distortion levels which translate to ultrasonic frequency harmonics.
It is difficult to get such information onto an LP and even harder to retrieve it accurately. And even if it is pressed into a disc, it probably will be wiped off it after a few plays
Καλά...καλά...καλησπέρα...χαίρετε κι αντίο...
Anyway τα 205/2 τα βρήκα εδώ...
http://www.stassen-hifi.com/en/catalogus/Luidsprekers/KEF/4
σε τιμή...σοκ...
Βέβαια δεν ξέρω πόσο σοβαρό είναι το μαγαζί...Γενικά έχει τιμές που θα κλαίνε πολλοί...
Απλά πρέπει να κάνει κάποιος την ταρζανιά να ψωνίσει πρώτος...για να δούμε...Αν το ξέρει κανείς ή έχει ψωνίσει κάτι από το παραπάνω μαγαζί ας το πει...
Manosmathiou
