Movies News
Jonah Hex
Και ο Malkovich προσθεθηκε στο cast της ταινιας μαζι με τον Josh Brolin.
Η ταινια αρχιζει γυρισματα τον Απριλιο του 2009.
SUPERMAN REBOOT TRILOGY
Oι αδερφοι Wachowski συζητανε με την WARNER για την δημιουργια μιας τριλογιας με τον superman.
THE GATE REMAKE
O Alex Winter ανελαβε το remake της ταινιας του Stephen Dorff's The Gate !
Η ταινια θα γυριστει σε full 3D !
IMPACT
While the entire world watches the largest meteor shower in 10,000 years, a brown dwarf, hidden by the meteor field, smashes into the moon in a tremendous explosion of rock and debris. Fragments of the moon itself, penetrate Earth's atmosphere and make impact. Even though the initial damage is minimal, nerves are frayed throughout the planet. Then strange anomalies begin to manifest themselves on Earth. It starts small - cell phone disruptions, unusual static charges and odd tidal behavior.
The world's leading scientists begin piecing together evidence that suggests the moon's properties, and its orbit, may have been permanently altered. Their fears are realized when the anomalies increase to the point where the effect of "simulated" gravity is being manipulated by increased electromagnetic surges coming from the moon. People, cars and other objects are rendered momentarily weightless in random, isolated areas around the globe. Alex, Maddie, Roland and the rest of their team soon discover something far worse - the moon's new orbit has put it on a collision course with Earth!
The world now has 39 days to stop it or Earth, and all of mankind, will perish.
Transformers: Revenge of the Fallen
2 μερες νωριτερα θα κανει τελικα πρεμιερα η ταινια συμφωνα με ανακοινωση της εταιρειας παραγωγης.
Ετσι η πρεμιερα θα γινει στις 24/6/2009.
DAY OF THE TRIFFIDS remake
To bbc ανακοινωσε το remake της ταινιας.
Θα ειναι μεγαλη παραγωγη και μεχρι τωρα οι ηθοποιοι που θα συμμετεχουν στην νεα ταινια ειναι οι :
Vanessa Redgrave, Joely Richardson, Eddie Izzard, Brian Cox, Jason Priestley.
Οριστικό το αντίο από τον Χοακίν Φοίνιξ
Ο γνωστός ηθοποιός δεν αλλάζει γνώμη με τίποτα απ’ ό,τι φαίνεται. Η ανακοίνωσή του πριν από μερικούς μήνες, να εγκαταλείψει την υποκριτική σε ηλικία μόλις 34 ετών και ενώ η καριέρα του πήγαινε περίφημα, σόκαρε πολλούς.
Δεν ήταν λίγοι αυτοί που έλεγαν ότι τελικά θα αλλάξει γνώμη ή ακόμα ότι το όλο θέμα δεν ήταν τίποτα άλλο από διαφημιστικό κόλπο.
Τον 34χρονο ηθοποιό πλέον κέρδισε η μουσική hip-hop, στην οποία σκοπεύει να δοκιμάσει το ταλέντο του.
«Από τη στιγμή που η μουσική αντικατέστησε την υποκριτική, δεν υπήρχε γυρισμός για μένα», δήλωσε χαρακτηριστικά ο Χοακίν Φοίνιξ και διάλεξε τον γραφικό τρόπο που βλέπετε στη φωτογραφία για να το… επισημοποιήσει.
Στην -εκ των πραγμάτων- τελευταία του ταινία, το «Two Lovers», ο Χοακίν Φοίνιξ πρωταγωνιστεί δίπλα στην Γκουίνεθ Πάλτροου.
Τα οπτικά εφέ του Μπέντζαμιν Μπάτον!
Για τον οσκαρικό Μπέντζαμιν Μπάτον έχουν γραφτεί πολλά και έχουν ειπωθεί ακόμα περισσότερα. Κι ενώ είχε κοπάσει η συζήτηση γύρω από το γεροντικό βρέφος που εξελίσσεται σε μωράκι τρίτης ηλικίας (με ενδιάμεση φάση έναν Μπραντ Πιτ - χάρμα οφθαλμών) η Paramount Pictures δημιούργησε ένα άκρως εντυπωσιακό κι ενδιαφέρον website, όπου αποκαλύπτονται τα μυστικά της οπτικής μαγείας, των ειδικών αυτών εφέ που μεταμόρφωσαν τον πρωταγωνιστή, αλλά και την πόλη όπου μεγάλωσε.
Με ένα έξυπνο εισαγωγικό σκίτσο, όπου καταγράφεται η αντίστροφη πορεία του κύκλου της ζωής του, το site (που σημειωτέον διατηρεί την αισθητική της ταινίας) είναι πραγματική απόλαυση, για όσους έχουν μια πιο εκτεταμένη περιέργεια γύρω από τις τεχνικές της κινηματογραφικής μαγείας, αλλά και την επιστημονική υποστήριξη των ψευδαισθήσεων της μεγάλης οθόνης. Ξεφυλλίστε το βιβλίο της ζωής του Μπέντζαμιν και ανακαλύψτε μέσα στις σελίδες του τα μυστικά της υποψήφιας για 13 Όσκαρ ταινίας.
Καλή πλοήγηση στο http://benjaminbuttonfx.com/
Τομ Κρουζ... περικυκλωμένος
Τομ Κρουζ και Ντένζελ Ουάσινγκτον θα ενώσουν τις δυνάμεις τους στη νέα ταινία που ετοιμάζει η MGM και ο σκηνοθέτης Ντέιβιντ Κρόνενμπεργκ, μεταφέροντας στη μεγάλη οθόνη το θρίλερ του Ρόμπερτ Λάντλαμ (The Bourne Identity) The Matarese Circle.
Τομ και Ντένζελ θα υποδυθούν δύο αντίπαλους πράκτορες (ένας της CIA κι ένας της KGB) που μετά από δύο δεκαετίες αλληλοκαταδίωξης συνασπίζονται εναντίον πανίσχυρης μυστηριώδους "δυναστείας" με το όνομα Matarese που τα μέλη της ετοιμάζονται να βυθίσουν τον κόσμο στο χάος και την οικονομική καταστροφή.
Το σενάριο, γραμμένο από τους Μάικλ Μπραντ και Ντέρεκ Xαας (Wanted) φέρνει στο σήμερα την ψυχροπολεμική περιπέτεια μυστηρίου του συγγραφέα του Bourne. Ο συνδυασμός Κρουζ, Ουάσινγκτον και Κρόνενμπεργκ κάνει το Matarese project ναυαρχίδα της MGM - δε συμμετέχει καθόλου η εταιρεία παραγωγής στην οποία ο Γερμανός αξιωματικός της «Βαλκυρίας» είναι συνιδιοκτήτης.
Με το αστρονομικό ποσό των τριών εκατομμυρίων δολαρίων που κατέβαλε η MGM για τα δικαιώματα των Matarese απέκτησε και το sequel με τίτλο The Matarese Countdown, αφήνοντας ανοιχτό το ενδεχόμενο για τη δημιουργία ενός franchise, όπως άλλωστε έκανε η Universal με το "σουξέ" του Λάντλαμ, τον Bourne.
Καλά απίστευτο!!:111: Νόμιζα ότι ήταν απλώς μακιγιάζ!!!
Who Is Doris Payne ?
H Doris Payne ειναι ενα υπαρκτο προσωπο και μαλιστα ειναι μια κλεφτρα κοσμηματων η οποια εδρασε για 5 δεκαετιες.
Η δραση της μεταφερεται στην μεγαλη οθονη με την Halle Berry να ενσαρκωνει την Doris !
Pride and Predator
Πριν λιγες μερες σας μιλησα για ενα project που εχει να κανει με την ταινια Λογικη και Ευαισθησια και με Zombies.
To νεο τωρα ειναι οτι ετοιμαζεται αλλη μια ταινια η οποια εχει παλι να κανει με ταινια εποχης οπως η Λογικη & ευαισθησια αλλα αυτη τη φορα εχουμε να κανουμε και με Pretadors.
Ταινια εποχης μαζι με εξωγηινους !!!
Σκηνοθετης ο Will Clark και τα γυρισματα θα γινουν στο Λονδινο.
O Sam Raimi ετοιμαζεται να κανει Remake την ταινια House of Flying Daggers !!!
Tωρα αυτο ειναι καλο ??? :111::139:
Ανήμερα του Αγίου Βαλεντίνου ο γάμος της Σάλμα Χάγιεκ
Από τις 14 Φεβρουαρίου, ανήμερα του Αγίου Βαλεντίνου, η Σάλμα Χάγιεκ βρίσκεται στο κλαμπ των παντρεμένων γυναικών.
Η διάσημη Μεξικανή ηθοποίος παντρεύτηκε τον σύντροφό της, τον Γάλλο επιχειρηματία Φρανσουά Ανρί Πινό, με πολιτικό γάμο, στο Δημαρχείο του Παρισιού, στο κομψό 6ο Διαμέρισμα.
Την είδηση, που επιβεβαίωσε η εκπρόσωπος της Χάγιεκ, γνωστοποίησε στα διεθνή μέσα ενημέρωσης ένας Γάλλος αξιωματούχος, υπό το καθεστώς της ανωνυμίας.
Σύμφωνα με τον ίδιο, η τελετή πραγματοποιήθηκε σε στενό κύκλο.
Οι νιόπαντροι γνωρίστηκαν στην Ιταλία το 2006. Το 2007 έγινε γνωστό ότι αρραβωνιάστηκαν, ενώ απέκτησαν και το πρώτο τους παιδί, την Βαλεντίνα Παλόμα.
Το 2008 ο αρραβώνας διαλύθηκε, αλλά -όπως φάνηκε- ο χωρισμός τους δεν κράτησε για πολύ...
The Expendables !
Eιναι η νεα ταινια του Stallone και το σημαντικο νεο ειναι οτι θα παιζει και ο Arnold Schwarzenegger !!!
  • loggeo
knazito
