Ακουστικα Sennheiser HD500
Πωλουνται, τα πολυ γνωστα και καλα ακουστικα, πληρους μεγεθους , Sennheiser HD500.
Με πολυ ωραιο και ζεστο ηχο, βαθια μπασα και ηρεμα πριμα.
Το καλωδιο συνδεσης ειναι αποσπωμενο και ειναι ολοκαινουργιο.
Τα ακουστικα ειναι σε καλη κατασταση με μικρη φθορα στο εσωτερικο μερος στα μαξιλαρακια , που μπορειτε να τα αλλαξετε κι αυτα με ελαχιστο κοστος..
Μπορειτε φυσικα να τα δοκιμασετε αν θελετε.
Μαζι δινεται και ανταπτορας απο μινι jack σε full jack.
Εχουν αγοραστει το 2008 , 150 ευρω.
Δινoνται 60 ευρω.
Specifications:
Frequency Response: 14-21,000 Hz
Power Handling Capacity: 100 mW
Impedance: 32 ohm
Sensitivity: 105 dB
THD: < 0.2%
Weight: 7.35 oz
Connector: 3.5 mm stereo mini-jack plug (gold-plated) with 1/4" adapter (gold-plated)
Features
Design: These headphones feature an around-the-ear design, with vinyl covered ear cups.
BioNetic Design: Sennheiser headphones adjust to the shape of your head, with their joints, flexible materials and extendable arms. Comfortable cushions provide optimum comfort in those places where sturdy material would rest on your head.
Diaphragms: The diaphragms of dynamic headphones consists of a very thin film that is caused to move by an attached coil. The less intrinsic oscillation this causes, the purer the sound reproduction will be. Sennheiser diaphragms are made of Duofol, a material specially developed by Sennheiser. As the diaphragm shape is optimized by computer, intrinsic oscillation is avoided to a very large extent.
Double-wound Aluminum Voice Coils: The HD 500 headphones have voice coils made of aluminum, an ultra-lightweight and very durable material. But Sennheiser takes this a step further and only double-winds these voice coils. Such a low-mass coil, together with an ultra-thin diaphragm, creates a part that can change direction very quickly, allowing more of the electrical music signal to be converted into sound waves.
Magnet System: These headphones use computer-optimized neodymium-ferrous driver magnets for deep bass and clear, crisp trebles.
Sintered Damping Elements: Sennheiser's high-quality headphones use a specially developed (patent pending) sintered bass damping element, which consists of semi-melted plastic pellets. This design reduces unwanted resonance for a cleaner sound.
Cable: Sennheiser connection cables are made of oxygen-free copper with Kevlar strands wound around the metal for added durability. The contacts are gold-coated for greater conductivity. The connecting cable is detachable.
Replaceable Parts: Sennheiser headphones are modular for long service life. Ear cushions, headbands, cables, and sometimes even driver elements are easily snapped out so new ones can take their place. photo.jpg
Απάντηση: Ακουστικα Sennheiser HD500
Συγνωμη για τη καθυστερηση... τα ακουστικα εχουν δωθει.
Ευχαριστω.
opanamas
