Για (παρόντες και μελλοντικούς) κατόχους Panasonic AE700 - Βρείτε το Service Menu σας!
Για όσους έχουν (ή πρόκειται να πάρουν) τον Panasonic AE700, το παρακάτω που βρήκα σε ένα forum πιστεύω είναι χρήσιμο...
To see your firmware version, look under "SELF CHECK" under service menu.
You access the service menu by:
Press Menu->Option
highlight "OSD"
Hold "ENTER" down for 3 seconds
You should get a menu that looks like :
FREEZE MSG (on)
HD OVERSCAN (off)
RUNTIME PRT (on)
FAN FULLMODE (off)
AUTO SETUP (normal)
SELF CHECK
SERVICE MODE
FLICKER ADJ
SD LEVEL (c)
525p OS (off)
HDCP1 (a)
HDCP2 (on)
It may look different if you have a very old firmware as the newer versions (1.05 and higher) they added a few things.
There is an entry in the service menu called "Service Mode" which provides many helpful test images. They can be used to check for stuck & dead pixels, as well as panel alignment and other potential problems. [NOTE: There is also a second service menu which can be accessed by holding down "ENTER" for three seconds while the "Pic Shift" selection is highlighted in the first service menu. The limited settings in that menu do not seem as useful.
Για οποιαδήποτε ζημία, ουδεμία ευθύνην φέρομεν!
Poll: Ποιά version του firmware έχετε;;
R1.03 A1.03 P1.04
Αγορά Δεκέμβριος 2004, λογικό να είναι από τις πρώτες εκδόσεις 8)
koskef
