[FONT=Verdana, Arial]When you’re ready to make the switch to pro studio monitors, there are many things you need to consider. For instance, it’s up to you to create a mix that works on a variety of speakers—one that translates to boomboxes, home and car stereos, even headphones and portable music players. So you need monitors that deliver a neutral starting point, and sound that is clear across the frequency spectrum. You also want monitors with consistent performance, so whether you’re on axis or off, cranking ’em up or turning ’em down low, what you’re hearing is accurate. And you want all this at a reasonable price.
[/FONT][FONT=Verdana, Arial]Technical specifications
• Studio monitor with true Active design
• Precision Class A/B amplifiers with Active protection circuits: 100W for LF/50W for HF
• HF and LF acoustic controls for room correction
• Balanced XLR, TRS and unbalanced RCA inputs
• Ultra-low distortion 8-inch steel frame LF transducer
• Waveguide loaded 1-inch high-resolution HF transducer
• Minimum-diffraction molded baffle for smooth, wide sweet zone
• Magnetically shielded for safe placement near computer/video monitor
• Precisely tuned for working interchangeably with other MR units [/FONT]
http://www.mackie.com/products/mrseries/index.html
46,3 KB Προβολές: 96
63,5 KB Προβολές: 95
