Ενεργό Subwoofer Αυτοκινήτου BLAUPUNKT GTb 8200 A
Dam
110 €
Specifications
• Bassreflex Subwoofer enclosure with integrated Class-D Amplifier
• Small dimensions: 250 x 272 x 260 mm
• 200 mm/8″ Subwoofer with Spun Paper Cone (SPC)
• Amplifier with high power handling: 75 watts RMS / 200 watts Max. Power
• Perfect matching Subwoofer
• Signal input via RCA/Cinch and highlevel
• Separate controls for lowpass filter, phase and gain
• Automatic On-/Off function via highlevel, RCA/Cinch and remote signal
• Central positioned Subwoofer
• Metall speaker protectors
• MDF housing material
• Stiched Blaupunkt logo on the top
• Perfect Price/Performance ratio
Amplifier
• Technical concept: Class-D
• Max Power (Watts): 200
• RMS Power (Watts): 75
• Frequency Response (Hz): 300-200
• Low Pass Filter (Hz): 70–190
• Phase (°): 0-180
• Input Sensitivity (V): 0.3-8
• Cinch (RCA) /high level inputs: 2 / 2
• Automatic on/off function: after approx. 30 seconds
• Power indicator color: Green
• Fault indicator color: Red
• Integrated fuses (number/value): 1 / 7.5 A
Subwoofer
• System: Single cone subwoofer
• Diameter (mm): 200
• Impedance (Ohms): 2 x 2
• Frequency Response (Hz): 30-200
• Sound pressure level dB(2.83 V/m): 92
• Cone Material: Spun Paper Cone (SPC)
Housing
• System: bass reflex
• Covering material / color: carpet / black
• Connections 12V/mass/switching voltage: screw terminals
• Dimensions (W x H x D): 250 x 272 x 260 mm
• Weight: 6.9 kg
Scope of delivery
• Installation and operating instructions: Yes
• Metal protectors for the subwoofer: yes
Dai Funka
