Ενισχυτής Aiyima A08 Class D
100€
Μεταχειρισμένος ελάχιστα, άριστη κατάσταση και αγρατζούνιστος. Τον είχα συνδεδεμένο με Klipsch R51M και πηγή laptop (tidal). Πωλείται λόγω αναβάθμισης. Περιοχή Άγιος Στέφανος Αττικής. Παρατίθεται η περιγραφή και τα χαρακτηριστικά του από την ιστοσελίδα του κατασκευαστή.
Product description:
TPA3255 is a high-performance class D power amplifier, it has class D efficiency and can bring true high-end sound quality. The device features advanced integrated feedback design and proprietary high-speed gate driver error correction function (PurePath™ Ultra HD). This technology allows the device to maintain ultra-low distortion throughout the audio frequency band while exhibiting perfect sound quality.
Features:
1.Adopt original TPA3255 chip
2.Built-in high-power HIFI special high-efficiency switching power supply, directly inserted into 220V
3.High precision chip resistor is selected to ensure good signal-to-noise ratio of the whole machine.
4.The use of audio-specific inductive, to ensure that the sound is crisp and powerful.
5.A small size of 101/93/184 mm, to meet your small space placement requirements.
Note: The initial password for Bluetooth connection is 0123.
Basic Parameters:
Amplifier IC: TPA3255
Output power: 315W/4Ω 185W/8Ω
Bluetooth version: Qualcomm QCC3034 5.0 chip
Decoder IC:pCM5102 decoding
Bluetooth support: CRS8675-SBC/AAC/APTX/APTX-LL/APTX-HD 16-24Bit 44.1Hz-48Khz
USB decoding: 16Bit-48Khz
Frequency response: 20Hz-20Khz
Input power: AC100-240 50/Hz
Operational amplifier: NE5532
Signal to noise ratio: (SNR)> 111dB
Impedance: 4-8Ω
Quiescent current: 60mA
Work efficiency:.>90%
Output Power:
315W/4Ω, distortion 10%
185W/8Ω, distortion 10%
260W/4Ω, distortion 1%
150W/8Ω, distortion 1%
Product size: 101*93*184mm
ΒΡΕΖΑ
