Ενισχυτής Class D Aiyima A08
Καλησπέρα σε όλους,
Πωλείται ο ενισχυτής του τίτλου στην τιμή των 100€ σε άριστη/αψεγάδιαστη κατάσταση αγορασμένος πριν λίγους μήνες από μέλος του φόρουμ.
Παρακάτω τα τεχνικά του χαρακτηριστικά τα οποία είναι ίδια με το A200 για τον οποίο μπορείτε να διαβάσετε κριτική στο Audio Science Review.
Product description:
TPA3255 is a high-performance class D power amplifier, it has class D efficiency and can bring true high-end sound quality. The device features advanced integrated feedback design and proprietary high-speed gate driver error correction function (PurePath™ Ultra HD). This technology allows the device to maintain ultra-low distortion throughout the audio frequency band while exhibiting perfect sound quality.
Features:
1.Adopt original TPA3255 chip
2.Built-in high-power HIFI special high-efficiency switching power supply, directly inserted into 220V
3.High precision chip resistor is selected to ensure good signal-to-noise ratio of the whole machine.
4.The use of audio-specific inductive, to ensure that the sound is crisp and powerful.
5.A small size of 101/93/184 mm, to meet your small space placement requirements.
Note: The initial password for Bluetooth connection is 0123.
Basic Parameters:
Amplifier IC: TPA3255
Output power: 315W/4Ω 185W/8Ω
Bluetooth version: Qualcomm QCC3034 5.0 chip
Decoder ICCM5102 decoding
Bluetooth support: CRS8675-SBC/AAC/APTX/APTX-LL/APTX-HD 16-24Bit 44.1Hz-48Khz
USB decoding: 16Bit-48Khz
Frequency response: 20Hz-20Khz
Input power: AC100-240 50/Hz
Operational amplifier: NE5532
Signal to noise ratio: (SNR)> 111dB
Impedance: 4-8Ω
Quiescent current: 60mA
Work efficiency:.>90%
Output Power:
315W/4Ω, distortion 10%
185W/8Ω, distortion 10%
260W/4Ω, distortion 1%
150W/8Ω, distortion 1%
Product size: 101*93*184mm
Ευχαριστώ πολύ.
Αριστος
