Ενισχυτής ONKYO Integra A-8650
Πωλείται ενισχυτης ONKYO Integra A-8650 σε άριστη κατάσταση σε χρώμα μαύρο. onkyo_8650.JPG
General
  • Manufacturer: ΟΝΚΥΟ
  • Model: A-8650
  • Model years: 1989 1990 1991
  • Manufactured in: Japan
  • Type: Analog
  • Remote control: no
  • Power consumption: 330 watts
  • Dimensions: 435 x 157 x 391mm
  • Weight: 12.5 kg
  • Color: black
Connections
  • Number of inputs: 7 stereo
    • 1 Phono MM: 2.5 mV/50kOhm, MC: 0.16 mV / 0,13 kOhm
    • 2 CD 150mV/30kOhm
    • 1 tuner 150mV/30kOhm
    • 1 DAT 150mV/30kOhm
    • 1 Tape / Video 150mV/30kOhm
    • 1 tape 150mV/30kOhm
  • Number of outputs: 4 speakers, stereo 3, 1 headphone
    • 2 x 2 speakers (switchable on the front) 4 / 8 ohms (banana / terminal)
    • 3 stereo tape recording 150mV/1kOhm (with phono, or passive)
    • 1 headphone jack 6.35 mm at the front
  • Other
    • Ground screw (eg for record players)
Specifications
  • Continuous Power (at THD)
    • 8 ohms: 90W x 2 (1kHz, DIN)
    • 4 ohms: 120W x 2 (1kHz, DIN)
  • Dynamic performance
    • 4 ohms: 167W
    • 2 ohms: 210W
  • THD: 0.008% at rated power, 0.008% at 1W
  • Damping factor: 150 (8 ohms, 1kHz)
  • Frequency response: 2Hz - 50kHz +0 /-1dB (CD / tuner)
  • Signal to Noise Ratio: Phono MM: 93dB (5mV input) Phono MC: 74dB (0.5mV input), CD: 107dB
  • Tone control:
    • Bass: + /-8dB at 100Hz
    • Treble: + /-8dB at 10kHz, high-cut filter: 6kHz (6dB/octave)
  • Loudness: no
  • Subsonic: only for Phono: 20Hz (-3dB, 6dB/octave)
  • Mute:-20dB
  • Direct / Line Straight: yes
  • Stereo channel separation: Yes
Τιμή 185 euro
phamis
