Ζητάω subwoofer
Καλησπέρα
Διαθέσιμο DEFINITIVE TECHNOLOGY SUB
Καινούργια κατάσταση με dsp με χαρτιά, συσκευασία, παρελκόμενα κλπ.
Εγγύηση - υπόλοιπο 4,5 έτη
Το δίνω λόγω αλλαγής σχεδίων.
Τιμή 450€
Τηλ. 6977210589
SUB SuperCube® 4000
High Performance 1200W Powered Subwoofer With 8" Woofer and Dual 8" Bass Radiators
Huge, accurate bass impact for movies and music from a compact enclosure, measuring only 12.88” x 12” x 13”
8” subwoofer driver pressure-coupled to two 8” Ultra Low Bass Radiators enhances speed, musicality and control
1200-watt digital tracking amplifier and 56-bit Digital Signal Processor (DSP) preamp stage improves performance
Disappearing alpha-numeric display and performance optimizer remote control allow precise system tweaking
Driver Complement
(1) 8" (20.32 cm) d (Round) - Subwoofer
(2) 8" (20.32 cm) d (Round) - Bass Radiator
Height 11.88" (30.18 cm) Width 11" (27.94 cm) Depth 12" (30.48 cm) Weight
45.6 lbs (20.68 kg)
CONTROLS
Display Type: Alpha Numeric (disappearing)
SIGNAL PROCESSING CROSSOVER
Filter: 40 Hz → 150 Hz, Slope of 12 dB per Octave
Phase Settings (Locked): 0°, 90°, 180°, 270°, 360°
INPUTS
Audio Inputs : Stereo Line Level - (2) RCA, Pair (L/R) Analog RCA
Speaker Inputs : (2) Pair of Speaker Cable - na
AUDIO QUALITY
Total Frequency Response: 16 Hz → 200 Hz
INTERNAL AMPLIFIER
Channels: 1
Amplifier Class: Class HD
Primary Protection Circuitry
Multiband Dynamic Range Optimizer (M-DRO)
POWER
US Power Cycle
Singnal Sensitive Auto On/Off
International Power Cycle
Switched & Signal Sensitive Auto On/Off
US Fuse Type
6.2 amp 250 volt Slo Blo
International Fuse Type
4 amp 250 volt Slo Blo
ACCESSORIES
Remote: Performance Optimizer Remote (Included with Subwoofer).
Remote: Type
Infrared: (IR)
Remote Features: Volume +/-, Mute, Night Mode On/Off, Low Pass Filter, EQ, Display, Phase, DSP
Included Accessories: (4) Carpet Spikes
WARRANTY
Electronics Warranty: 3 years
Cabinet Warranty: 5 years
Drivers Warranty: 5 years
SHIPPING CARTONS
Carton 1
Να πω ότι θέλω 10 ιντσο τουλάχιστον και χρήση για home cinema καο όχι για μουσική.
Ευχαριστω
koskef
