ΗΑFLER DH 200
POWER RATING: 100W-8 ohm at any frequency between 20HZ and 20KHZ both channel driven
IMD (SMPTE): Less than 0.005% from 1 to 100 W into 8 ohm
FREQUENCE RESPONSE: ±0.5 dB 10 HZ to 40 KHZ at 100W
TYPICAL CHANNEL SEPARATION: 60 dB
SIGNAL TO NOISE RATIO: Better than 100dB at 100W into 8 ohm
INPUT SENSITIVITY: 1.5V RMS for 100W into 8 ohm
SLOW RATE: 10 KHZ, 60V peak to peak square wave :25V/μs
Σε αριστη κατασταση.Ο ενισχυτης ειναι φιλου και πωλειται προς 200 ευρο.Δουλευει και σαν μονομπλοκ.Επικοινωνια 6938103010
pablonou
