ΗΧΕΙΑ REFERENCE KLIPSCH RF-25
ΠΡΟΚΕΙΤΑΙ ΓΙΑ ΤΑ ΗΧΕΙΑ RF-25 ΤΗΣ KLIPSCH ΣΑΝ ΚΑΙΝΟΥΡΓΙΑ. ΕΙΝΑΙ ΠΟΛΥ ΕΥΑΙΣΘΗΤΑ ΚΑΙ ΜΠΟΡΟΥΝ ΝΑ ΕΡΓΑΣΤΟΥΝ ΚΑΙ ΜΕ ΠΟΛΥ ΜΙΚΡΟ ΛΑΜΠΑΤΟ ΕΝΙΧΥΤΗ (8WATT). ΔΕΧΟΝΤΑΙ ΜΕΓΙΣΤΗ ΙΣΧΥ ΚΟΡΥΦΗΣ 400WATT.
e-mail: [email protected]
RF-25 Floorstanding Loudspeaker
Detailed Description
The Reference Series RF-25 floorstanding loudspeaker was first introduced in 2003 and manufactured by Klipsch until 2006. Featuring the same dynamic quality, superior sound and cosmetic appeal as the RF-35 model, the RF-25 came in a smaller package with a more affordable price tag.
RF-25 Specifications
frequency response45Hz-20kHz ±3dBpower handling125 w max continuous (500 w peak)sensitivity97dB @ 2.83 volts/1 meternominal impedance8 ohms compatiblecrossover frequency2633HztweeterK-137 1" (2.54cm) Titanium dome compression driverhigh frequency horn6" square 90°x60° Tractrix® HornwooferTwo K-1123-OB 6.5" (16.51cm) Cerametallic® cone / cast polymer frameenclosure materialMDFenclosure typeBass reflex via rear-firing portinput connections2 sets of binding post speaker terminals (connected via brass strap jumpers)dimensions38.9" (98.8cm) x 8.5" (21.6cm) x 13.8" (35cm)weight44 lbs. (20kg)finishesBlack Ash, Light Cherry wood-grain vinylbuilt from2003built until2006
Antonis N.
