Σε άριστη κατάσταση.. τιμή 150 ευρώ.
SPECIFICATIONS
High Frequency 1" tweeter, shielded
Low Frequency 6.5" bass driver, shielded
Dispersion 90 degrees @ -6dB
Nominal Impedance 6 ohms
RMS Power Rating 50 Watts
Program Power Rating 100 Watts
Frequency Response 63Hz to 51kHz
Sensitivity (1W/1m) 90 dB @ 1W @ 1M
Distortion <0.6%
Shielding Yes
Recommended Amplifier Power 50Watts - 100 Watts @ 8 ohms
Crossover Frequency 2.9kHz
MATERIALS
Low Frequency Material Multi Fiber Paper Pulp
WideBand Tweeter Material Titanium Dome
WideBand Tweeter Magnet Lightweight Neodymium
CONSTRUCTION & DIMENSIONS
Enclosure Type Optimized bass-reflex loaded
Shipping Dimensions (H x W x D) 24.5"H x 11.25"W x 17.375"D
Baffle Thickness 40mm / 1.57"
Baffle/Cabinet Material MDF
Cabinet Thickness 18mm / .71"
Baffle/Rear Joinery Tongue & Groove
Finish Grey cabinet & Maroon baffle
Weight 16 kg. / 35.3 lbs
SPECIFICATIONS
Distortion <0.6%
Shielding Yes
MATERIALS
