Ηχεια Dynaudio Audience 72 (δαπεδου) & 42C (κεντρικο) & ενισχυτης NAD T 752 & subwoofer B&W ASW300
vasilisnt
Golden Boy!
Για λογαριασμο φιλου και εξαιτιας ενος μπομπιρα που γυρναει μεσα στο σπιτι...
ολο το πακετο 1300 ευρω, συζητησιμο το σπασιμο
επικοινωνια κ. Γιωργος 6985883377 (οχι αστεια παζαρια)
Audience 72
Sensitivity (2.83 V/1 m): 86 dB
IEC Long Term Power Handling: 230 W
Impedance: 4 Ohms
Weight: 17.7 kg
Dimensions (W x H x D): 204 x 959 x 256 mm
Audience 42 C
IEC Long Term Power Handling: 150 W
Impedance: 4 Ohms
Weight: 6.9 kg
Dimensions (W x H x D): 370 x 165 x 200 mm
NAD T 752
• 5 x 80W Simultaneous Continuous Output Power into 4/8 ohms
• 150W, 200W, 225W, IHF Dynamic Power into 8, 4 & 2ž, respectively.
• PowerDrive™ • Dolby Digital, Dolby Digital EX, DTS ES, DTS NEO:6, Matrix 7.1, Dolby Pro Logic II, EARS and Stereo Enhanced Surround Modes
• 5 A/V Custom Presets store unique settings • Direct access speaker level adjustment for surround, center and subwoofer
• 6 A/V Inputs all S-Video and Composite, 2 full tape loops • Component Video on 2 Inputs and 1 Output
• 3 Audio Inputs, 1 tape loop
• 6 Digital Inputs, 4 Coaxial, 2 TOS Link freely assignable • 2 Digital Outputs, 1 Coaxial, 1 TOS Link
• 7.1 Analogue Input (for DVD-Audio)
• 2 x 12V Output Triggers, 12V Input Trigger
• 2 x IR Outputs, IR Input • IEC detachable power cable
• Preamp Outputs for all channels (2 Subwoofers)
• Amplifier Input for front and center power amps
• RDS FM/AM Tuner with 30 direct access presets
On Screen Display • NAD Soft Clipping™ • HTR-2 Remote Control
B&W ASW 300
Description: Active vented-box subwoofer system
Amplifier power output: 100W continuous Frequency range (-6dB): 23Hz and 180Hz
Dimension: (including feet) H 405mm W 330mm D 375mm H 16” W 13” D 14.8”
Frequency response(±3dB): 27Hz and 150Hz Weight: 15kg / 33 lbs
Vaslamp
