Σε κατάστημα που ασχολείται με plexiglass είχα φτιάξει πριν από μερικά χρόνια.
Του συγκεκριμένου πικάπ δεν είναι κάτι ιδιαίτερο σαν σχήμα, ώστε να δυσκολέψει.
Dual Part Number: 282616 = 288660 Please refer also to the dimensions at the pictures, especially the hinge distance! Used in Dual Models (without guarantee): CS455-1 newer models since ~2015, CS460, CS503-1, CS503-2, CS505-3, CS505-4 Also ...
For your consideration is this new aftermarket dust cover made for a Dual 505-2 turntable. There were two lid versions with the 505-2, this is the lid for rear mounted hinges and Not the slotted top side insert hinge version. I do Not make these myself, I use a local one man Acrylic shop and...
