Νέο Interface σύνδεσης από τη VESA
gkontoletas
trouble in my brain
Top PC Companies Support New VESA DisplayPort Standard
ROUND ROCK, Texas & PALO ALTO, Calif., & RALEIGH, N.C.--(BUSINESS WIRE)--May 3, 2006--Dell, HP and Lenovo today jointly announced their support for the newly released DisplayPort 1.0 digital display interface standard developed by the Video Electronics Standards Association (VESA). Dell, HP and Lenovo are VESA members. DisplayPort is designed for broad application in PCs, monitors, TV displays, projectors, and other sources of display content.
DisplayPort enables a common interface signaling approach for both internal and external display connections. This approach can reduce overall design complexity, making digital displays such as LCD monitors easier to use and more affordable for customers.
The new display interface standard addresses low-voltage operation, enabling integration into the latest generation of silicon process geometries for graphics, while still supporting cost-effective integration into the current generation of LCD panels.
"DisplayPort is an excellent customer solution that can provide advantages over current and other emerging interfaces. DisplayPort can enable more-affordable flat-panel displays, support protected high-definition content, and scale performance to meet the demands of next-generation displays by enabling new features and usages. With VESA administering the specification, the industry can take advantage of an open and extensible path for support, compliance, and future upgrades," said Kevin Kettler, Dell's Chief Technology Officer (CTO).
Legacy compatibility with DVI 1.0 is also possible for DisplayPort products, providing a means for interoperability with legacy equipment when needed.
"HP is proud to be a supporter of the DisplayPort development effort within VESA," said Phil McKinney, vice president and chief technology officer, Personal Systems Group, HP. "This new open standard provides an innovative approach to meeting the future digital display interface needs of the industry and will enrich customers' technology experience."
DisplayPort is also designed to efficiently accommodate the higher display resolutions and color depths enabled by Microsoft's next-generation operating system, Windows(R) Vista. This new operating system is designed to provide greatly enhanced support for higher-resolution displays.
"Compared with proprietary specifications, DisplayPort introduces an open and extensible solution that protects past investments and supports future innovation, which will ultimately benefit our customers," said George He, Senior Vice President and Chief Technology Officer of Lenovo.
The DisplayPort specification also addresses the industry need for a ubiquitous digital interface standard with a compact connector, as well as optional content protection, that can be deployed widely at low cost. A protected digital interface that can be easily deployed on a PC enables broad access to premium content sources such as high-definition movies.
The DisplayPort interface is designed to be used for all types of digital display connections, including internal connections in a notebook, monitor, or TV. This capability makes it possible to avoid the costly signal translation from one display format to another that is required with today's display interfaces.
Going forward, the micro-packet architecture of DisplayPort can support new innovative features and display product usages that are not possible today with DVI or HDMI.
H DELL, η HP και η LENOVO υποστηρίζουν επίσημα πλέον το νέο πρότυπο σύνδεσης DisplayPort.
Προσέξτε τι γράφει στο σημείο περί Legasy compatibility with DVI… μια μικρή μετάφραση ‘είναι δυνατή η συμβατότητα με DVI 1.0 αλλά αν θέλουμε και όπου θέλουμε’.
Α ναι και κάτι άλλο είδατε να γράφει πουθενά HDCP; όχι ε, φυσικά αφού θα έχει νέο σύστημα προστασίας το οποίο φτιάχνει η PHILIPS
http://www.vesa.org/press/VESA_dportlaunchpr_Final.htm
http://www.vesa.org/press/dellhplenovopr.htm
gkontoletas
trouble in my brain
VESA DisplayPort v1.1
Video Electronics Standards Association (VESA) Approves DisplayPort Version 1.1: Latest Version Supports HDCP, Enables Broad Industry Support
Milpitas, Calif., April 2, 2007 – The Video Electronics Standards Association (VESA) announced today that its membership has approved version 1.1 of the DisplayPort™ interface standard for use in new designs of flat panel displays, projectors, PCs and CE devices.
DisplayPort 1.1 gives manufacturers of LCD panels, monitors, graphics cards, PC chipsets, projectors, peripherals, components, and consumer electronics a next generation digital interface that is designed to replace LVDS, DVI, and eventually VGA. DisplayPort provides the ability to connect to both internal and external displays with a common digital interface. This common interface capability means that DisplayPort can carry pixels directly from any display source to any LCD panel, simplifying the design complexity that is present today. As presented at CES 2007, a DisplayPort Interoperability Guideline is nearing completion that recommends best practices for providing DVI and HDMI connectivity via the DisplayPort connector and simple cable adapters.
DisplayPort 1.1 adds support for High Bandwidth Digital Content Protection (HDCP) version 1.3. HDCP support enables viewing of protected content from Blu-ray and HD-DVD optical media over DisplayPort 1.1 connections.
DisplayPort 1.1 provides for low voltage and low power operation, and enables improved interoperability and reduced EMI through its unique embedded clock architecture. Significant advantages over DVI and VGA include a small USB-sized connector with available latching, two-way display connectivity, optional audio support, higher performance than dual link DVI at 10.8 Gigabits per second, and a unique micro-packet architecture that enables new display features.
“The benefits of version 1.1 are significant, and will encourage adoption of DisplayPort in new generations of computers and consumer electronics equipment,” said Bill Lempesis, VESA executive director. “Our task groups and committees within VESA worked very hard to ensure that DisplayPort 1.1 satisfies the important objectives it is designed for, and as a result, this new version has widespread support among all the leading computer and consumer electronics suppliers.”
Available throughout the industry as a free to use, open and extensible standard, DisplayPort is expected to accelerate adoption of secure digital outputs on PCs, enable higher levels of display performance, and introduce high volume digital displays that are simpler, thinner, and easier to use than VGA.
HV
HDMI θυμιζει απειλητικα...
Τελικα ο Ανδρεας δεν θα το ξεφορτωθει ποτε αυτο το κλιπ :p
Ε....άει στο διάτανο....μας αλλάζουν τα φισάκια κάθε 2-3 χρόνια για να μας αμαγκάζουν να πετά με όλο τον εξοπλισμό.
ΡΕ ΟΥΣΤ! :mad_2: :pc:
koskef
