Σημερα πηρα το παρακτω e-mail:
Firmware 1.4.52!
TViX HD M-4100SH / TViX PVR M-4110SH / TViX PVR M-4130SH
TViX HD M-5100SH / TViX PVR M-5110SH / TViX PVR M-5130SH
Dear Customers. We just release a new formware for M-4100SH/5100SH which version is 1.4.52. Download Link Please enjoy your TVIX. Best regards,
Change note from 1.3.15
1. Better AVI file compatibility and response time by adapting own RFX engine.
2. Subtitle compatibility enhanced
3. Better compatibility TS/TP/M2TS/MTS file playback
4. VC-1 codec added in MKV playback
5. 120Hz file support added
6. Subtle stutter removed in NTSC/PA/24Hz mode
7. NTSC/24Hz, PAL/24Hz added
Not much change about JPEG and music play.
Most frequently asked hardware limitation
WMV7,8(WMV 1,2), WMV9 AP@HL not supported
H.264 support up to [email protected] only
MJPEG not supported
Our next top priority to-do list.
Enhancement in JPEG slide show
DTV Improvement :
1. Supports IceTV EPG for Australia.
[ Using IceTV EPG Guide ]
2. The location of the recording scheduler file(schedule.data) was changed from internal hard di sk to Flash Rom.
- Improved the problem that the TViX does not boot after the recording time set passes.
Note :
After upgrade, the setup value will change to factory default because we changed setup structure.
We are sorry for the inconveniences and you may not see the picture after upgrade.
Please use the TVOUT button in the remote transceiver to see the screen and go to the setup menu to set the video output mode of your choice.
If your default OSD language is different from your language, please change to the preferred language.
How to change the Factory setup (Changing Language)
Οσοι πιστοι προσελθετε στο site της DVICO γιατι δεν μπορω να αντιγραψω το link!
Firmware 1.4.52!
MJPEG not supported
DTV Improvement :
Note :
