λογω αναβαθμισης πωλειται ο γνωστος ενισχυτης της pioneer.
Input & Output connections
Apple Compatibility
Network Features
Surround Sound Formats
ΤΙΜΗ ΣΤΑ 320ΕΥΡΩ
ΤΙΜΕΣ ΣΚΡΟΥΤΖ
http://www.skroutz.gr/s/342506/Pioneer-VSX-921.html
- Output Power per Channel150W
- Impedance at Output Level6Ω
- Number of Channels7
- Signal / Noise Ratio100 dB
- Input Connections• 4 x HDMI (1080p upscaling)
• 5 x Composite
• 2 x Component
• 1 x Coaxial
• 2 x Optical
• 2 x USB host
• 1 x iPod/iPhone Digital via USB (cable included)
• 1 x Ethernet
• 1 x Bluetooth adapter port for AS-BT200 - Output Connections• 1 x HDMI
• 1 x Composite
• 1 x Component - AM/FM Tuner with RDSYes
- Tuner Pre-set Stations30
- File PlaybackLPCM, MP3, WAV, AAC, WMA Lossless, Apple Lossless, FLAC
- HD Audio FormatsDolby TrueHD, DTS-HD Master Audio
- Audio Return ChannelYes
- Stand-by Pass ThroughYes
- Control with HDMI (+)Yes
Put simply, KURO LINK means that you are able to control basic functions of compatible Pioneer Audio/Visual devices* (such as your Blu-ray player, amplifier or DVD recorder), with your KURO flat-screen TV remote control.
One remote for your full entertainment system.
KURO LINK is made possible via the single HDMI cable connection between your flat-screen TV and your other entertainment devices.
* Other brands of TV and home entertainment components also work with the KURO LINK function (here’s a list) - HDMI Repeater (+)Yes
The HDMI Repeater feature makes a single HDMI cable sufficient to transfer both HD video and audio digitally to the receiver. - On-Screen Display (GUI)Easy-to-use GUI, available in English, French, Italian, German, Spanish, Dutch and Russian
- Firmware updatesYes (via Internet or USB)
- AVNavigatorYes
- Internet RadioYes
- vTunerYes
- DLNA Certified (+)Yes (v1.5)
DLNA stands for the Digital Living Network Alliance, and is an organisation of consumer electronics, computing and mobile device companies.
The DLNA certification logo (it's the logo on the right) makes it easy to find products that comply with the DLNA Interoperability Guidelines. - Remote ControlGlow-key, preset remote control
- Weight9,9 kg
- Dimensions (W x H x D)435 x 168 x 362.5 mm
- AV Front InputYes
- Bi-AmplifierYes
- Bluetooth Adapter Port (+)Yes
Connect a Bluetooth adapter to this port to access the Bluetooth features of your product. - Component Video Input/Output2/1 (assignable)
- Composite Input/Output4/1
- Digital Optical Input/Output2/- (assignable)
- Digital Coaxial Input/Output1/-
- Ethernet (+)1
An Ethernet cable connects end systems to a network, for example, your amplifier to your home network.
A standard Ethernet cable looks like a telephone wire.
Depending on which model you choose, you could listen to Internet radio as well as enjoy your digital photos (JPEG images) and music stored on one or more network servers.
The benefit is an easy integration into your home network., for example - HDMI Input/Output4 (assignable)/1
- HDMI version1.4a
- HeadphoneYes
- IR In/Out (+)1/1
The IR In/Out feautre is useful for the custom installer business. By using IR repeaters, IR control of A/V components and the receiver is made possible when the equipment is hidden in a cabinet or located in a second room. Independent remote codes have also been developed for easy receiver control when utilising the second room function, e.g. independent power, source selection, volume and tuner control. - Large speaker terminalsYes
- Pre-amp Output Yes (SW)
- USB Host (Front) (+)Yes
Play back music data stored on your USB memory stick directly via the USB port on the front of the AV Receiver - and experience music with full and dynamic sound quality.
Apple Compatibility
- Works with iPodYes (cable included)
- Works with iPhoneYes
- Works with iPadYes
- AirPlayYes
- Air JamYes
- iPhone Control Button (+)Yes
As standard, you navigate through your iPod/iPhone with your receiver’s remote control. If however you want to browse through your media files directly on your iPod/iPhone, just press this button. - Compatible Generations• iPod: 5th Generation, Nano and above
• iPhone 3G, 3GS, 4
• iPad, iPad 2 - Supported Functions• Audio & video playback
• On-screen album art
• Charging
Network Features
- Wireless LANYes (with optional AS-WL300 adapter)
- Dolby Digital (+)Yes
The current surround sound quality decoding standard, Dolby Digital means movie theatre sound performance for a home cinema. The listener will be wrapped in surround sound by 5.1-channel audio sound compression technology.
Depending on the speakers, the front left and right, centre, rear left and right speakers can span frequencies from 20 Hz - 20 kHz and there is a dedicated subwoofer channel for additional low frequency sound effects. Extra features mean not only stunning soundtracks but also additional language tracks on one disc. - Dolby Digital EX (+)Yes
THX Surround EX/Dolby Digital EX is a joint development of Dolby Laboratories and the THX division of Lucasfilm Ltd. This phenomenal technology was first heard in George Lucas' 'Star Wars: Episode I - The Phantom Menace'. Now applied to home cinema, EX technology creates an extra 'Surround Back' channel, which may have been added when the programme was mixed.
By decoding the surround back channel from the left and right surround channels of 5.1 soundtracks, this additional surround back channel allows more detailed imaging behind the listener and brings more depth and better sound localisation than ever before, to give you the feel of 6.1 channels.
THX Surround EX/Dolby Digital EX is compatible with Dolby Digital 5.1, so that regular Dolby Digital decorder can decode EX signals as a normal 5.1 signal. - Dolby Digital Plus (+)Yes
Dolby Digital Plus is a digital audio compression scheme developed specifically for Blu-ray Disc.
It is a development of the earlier Dolby Digital system. Compared to Dolby Digital, it supports a greater range of bitrates at higher quality and up to thirteen full range audio channels compared with Dolby Digital's original five. - Dolby Pro Logic II (+)Yes
Dolby Pro Logic II is an improved version of Dolby Pro Logic technology with extended matrix decoding technology that can create 5.1 channel sound from two channel sources. Dolby Pro Logic II creates basic 5 channel sound by using the innovative "steering logic" circuit.
Therefore when listening to typical two-channel sources like CD, the listener can enjoy a richer spatial effect. When using software encoded with Dolby Surround, this decoding system affords the listener an improved surround experience with greater sound detail. - Dolby Pro Logic IIx (+)Yes
Dolby Pro Logic IIx expands upon the popular Dolby Pro Logic II technology.
With Dolby Pro Logic IIx, these receivers have the ability to process 2- or 5-channel sources into 5.1 or 6.1- or 7.1- channel output according to the model and speaker configuration.
Dolby Pro Logic IIx creates a seamless, natural wraparound sound field that does not require specifically encoded programme content.
You can also enjoy improved surround envelopment, enhanced spatial depth, improved directionality and a larger 'sweet spot'.
Movie and Music modes can be used to match the sound experience even more closely to the source.
Three additional Music parameters are also available: Dolby Center Width (focuses the vocal balance to the centre and front), Dolby Panorama (creates a seamless surround effect) and Dolby Dimension (creates a deeper or shallower surround field). - Dolby Pro Logic IIz (+)Yes
Dolby Pro Logic IIz is based on Pro Logic IIx. It adds a height component, creating front height channels above the front left and right speakers. This expands a 5.1 or 7.1 system to 7.1 Height or 9.1.
It identifies low-level information such as ambience and weather sounds and directs it to the front height speakers. - Dolby True HD (+)Yes
Both codecs are intended primarily for high-definition home-entertainment equipment, such as Blu-ray Disc.
Put simply, the result is that you can now enjoy high resolution images accompanied by lush studio-quality HD sound. - DTS (+)Yes
DTS 5.1-channel playback decoding technology has rapidly gained popularity thanks to its dynamic sound impact that flies at the listener from left, right and centre surround speakers. - DTS-ES (+)Yes
DTS-ES (Extended Surround) includes two variants, DTS-ES Matrix and DTS-ES Discrete 6.1, depending on how the sound was originally mastered and stored.
DTS-ES Discrete provides 6.1 discrete channels, with a discretely recorded centre-surround channel. In home cinema systems with a 7.1 configuration, the two rear-centre speakers play in mono.
DTS-ES Matrix provides 5.1 discrete channels with a matrixed centre-surround audio channel. DTS-ES commonly works on a matrix system, whereby processors that are compatible with the ES codec look for and recognise "flags" built into the audio coding and "un-fold" the rear-centre sound from data that would otherwise be sent to rear surround speakers. - DTS Neo: 6 (+)Yes
DTS NEO:6 modes apply conventional 2-channel signals to the high-precision digital matrix decorder and achieves 6.1-channel surround playback. High-precision input signal detection and matrix processing enable a full band reproduction for all 6.1 channels.
It also improves the separation between the different channels to almost the same level as that of a digital discrete system.
DTS NEO:6 Cinema Mode
decodes with an emphasis on separation performance to achieve the same atmosphere with 2-channel sources recorded in conventional surround formats as it does with 6.1-channel sources. The original 2-channel signal is distributed into 6 channels thanks to the sophisticated DTS matrix technology. Meanwhile, the effect of the surround signal output from the centre and surround channels adds a natural sense of expansion to the sound field.
DTS NEO:6 Music Mode
the front channel signals bypass the decorder and are played directly, so there is no loss of sound quality. - DTS 96/24 (+)Yes
The the multi-platform DTS 96/24, was first compressed surround format technology to support 96 kHz and 24-bit sound resolution and multi-channel capabilities - the best multi-channel audio format for DVD-Video.
With its super low audio compression rate compatibility, both DTS 96/24 and traditional DTS-encoded audio discs will sound rich and sophisticated, with sound quality almost as high as on 96 kHz, 24-bit master tapes in the studio.
Backwards compatible with existing DTS decorders, the listener is also able to enjoy DTS 96/24 discs with receivers incorporating a standard DTS decorder. - DTS-Express (+)Yes
DTS uses a system called DTS Express to deliver Secondary or Sub Audio to your player. The DTS Express audio is mixed with the Primary Audio, giving you an intensely great interactive surround experience. - DTS-HD High Resolution Audio (+)Yes
DTS-HD Master Audio, is an extension to the original DTS audio format. It delivers up to 7.1 channels of sound at 24-bit depth resolution.
DTS-HD High Resolution Audio is selected as an optional surround sound format for Blu-ray Disc with constant bit rates up to respectively 6.0 Mbit/s and 3.0 Mbit/s. It is supposed to be an alternative for DTS-HD Master Audio where disc space may not allow it. - DTS-HD Master Audio
ΤΙΜΕΣ ΣΚΡΟΥΤΖ
