Πωλουνται ηχεια zingali 2Β για λαμπατους ενισχυτες 750€.
:119:
Specifications :
System.........................................Bass reflex
Frequency range............................50Hz - 20KHz
Nominal impedance........................4 ohms
Efficiency......................................91dB
Cross-over frequency......................1500 Hertz, 6/12 railways per Octave
Maximum stress RMS...................150 Watts
Recommended Amplifier Power.......Starting from 10 Watts
Connection system........................Bi-Wiring
Components..................................Bass Woofer - 2 x 6 inches (145 mm), 32 mm of moving coil
...................................Tweeter - 1 inch (25 mm), 19 mm of moving coil
...................................Wood horn - 6.5 inches (172 mm), Omniray ZG
Dimensions(w x d x h)....................21 x 30 x 87 cm
Weight..........................................19kg per side
ΚΑΙ ΦΩΤΟΓΡΑΦΙΑ ΤΩΝ ΗΧΕΙΩΝ
ΤΗΛΕΦΩΝΟ 6944787280.
:119:
Specifications :
