Παθητικος προ Placette Audio - Remote Volume Control
Σε πραγματικα αψογη κατασταση στο κουτι του
The Remote Volume Control has the Placette Audio 125 step attenuator that uses only Vishay resistors. The input impedance is a constant 9k ohms at every volume setting. The remote control allows for easy operation while at the same time placing it close to the power amp for the shortest possible output interconnects.
Although passive, these units do not suffer the usual loss of dynamics or bass response associated with other passive designs because of the non-inductive load offered by the Vishay S-102 resistors that are use throughout the volume control circuits. These controls will allow the sound of your sources to come through in full without the grain and brightness caused by typical volume controls including the "variable out" that is available on some source components.
http://www.placetteaudio.com/remote_control.htm
http://www.stereophile.com/solidpreamps/604placette/index.html
540ευρω
τηλ. 6983366504
Γιωργος
Απάντηση: Παθητικος προ Placette Audio - Remote Volume Control
Πουληθηκε παρακαλω να κλεισει
Spiromag
