Πωλείται 2-Channel Compact Flash Field Recorder
panosop
Συστημικός
Πωλείται σε άριστη κατάσταση δικάναλος ψηφιακός εγγραφέας Fostex FR-2 LE - 2-Channel Compact Flash Field Recorder για οποιαδήποτε χρήση, υψηλής ποιότητας, για δημοσιογραφική, εκδηλώσεων, μετατροπή απο analog to digital ADC-DAC. Εχει ενσωματωμένο μικρόφωνο, μπορεί να πάρει οποιοδήποτε εξωτερικό, XLR, αναλογικές εισόδους κλπ. Συνδέεται με PC USB 2.0 και γραφει σε κάρτα CF.
Διατίθεται η συσκευη μαζι με κάρτα 1GB και το τροφοδοτικό του.
Στα 390 ευρώ.
Περισσότερα : http://www.fostexinternational.com/docs/products/FR-2LE.shtml
Αναλυτικά :
The Fostex FR-2 LE is a 2-channel compact field recorder that records stereo or mono BWF or MP3 files to Type II CompactFlash or Microdrive cards with up to 24-bit/96kHz resolution. The unit features built-in phantom powering, editing functionality, and USB 2.0, allowing high-speed transfer to Mac or PC computers. A pre-record buffer ensures full-take recording with no inadvertant loss.
2-channel field recorder in Stereo or Mono on Compact Flash or Micro drive cards Maps in the standardized, PC-compatible BWF file format FAT32 file system Large bright back lit display and built-in phantom power for condenser microphones Linear data recording with 24 Bit/96 kHz and compressed MP3 recording formats supported Two-hour capacity on 4GB CF card with Stereo 24 Bit/96 kHz resolution
Pre-record buffer ensures full take recording with no inadvertant loss USB data transfer to Mac or PC computers for further editing and post-production Ultra-lightweight and compact for convenient field use
Superb recording quality anywhere you need it.
The Fostex FR-2LE is a two-channel field recorder that records BWF or MP3 files in stereo or mono to Type II CompactFlash or Microdrive cards. You get up to 24-bit/96kHz resolution and a two-second pre-record buffer to ensure full-take recording. "File per Take" system allows onboard scene and auto-take naming, or via external keyboard using the USB port. AA-size NiMH batteries let you work in the field for approximately 2 hours. The FR-2LE also features built-in phantom powering, editing functionality, and USB 2.0.
Features
  • Recording on Type II CompactFlash card
  • Light weight and highly rigid chassis
  • FAT32 file system & BWF Stereo file format + MP3 recording/playback
  • High resolution recording of maximum 24-bit/96kHz
  • 132 x 64 dot matrix LCD
  • USB 2.0 connector for high speed file transfer to PC
  • Pre Rec buffer for 2 seconds
  • 1 take = 1 file system to eliminate overwriting
  • Auto Shut-off function when the input power becomes abnormally low to save data
  • 2 x XLR mic inputs with phantom power to accept various professional microphones.
  • Mic Trim for accurate recording level adjustment
  • ALC (OFF/ALC/LIMITER) and HPF
  • Buit-in Stereo microphones for quick memo recording
  • Auto File Closing: the recording file automatically closes every one minute to secure the up-to-then recorded data.
  • Convenient file naming mode: DATE or TAKE
  • Approx. 8 hours operation with off-the-shelf Tamiya RC3600HV, Ni-MH battery
panosop
Συστημικός
Απάντηση: Πωλείται 2-Channel Compact Flash Field Recorder
μια γενναια μείωση τιμής στα 300 ευρώ. Πρόκειται για μια συσκευη που πραγματικά λύνει τα χέρια στον χρήστη για εγγραφές ποιοτικές, στον ερασιτέχνη, αλλά και στον επαγγελματία. Κάνει εγγραφές απο εσωτερικό μικρόφωνο, εξωτερικό μικρόφωνο, αναλογικές πηγές, xlr, κλπ. Ειναι φορητό, δουλεύει με μπαταρία και ρεύμα και για δημοσιογραφικές ή συνεδριακές εργασίες ειναι must...
panosop
Συστημικός
και μια τελευταία στα 270 ευρώ... Φοβερό μηχάνημα, για τον ερασιτέχνη και τον επαγγελματία...
panosop
Συστημικός
στα 250 ευρώ...
nikPIT
