Πωλείται το Active Subwoofer Qln SUB 12 σε άριστη κατάσταση. Περιοχή Θεσ/νίκη, στέλνω και αντικαταβολή με έξοδα του αγοραστή. Τηλ 6943969932, Γιάννης. Τιμή 250Ε
Features
Principle: Bass reflex
Power: 180 W
Woofer: 12″ heavy duty
Variable low pass filter: 40 – 180 Hz
Variable phase: 0 – 180°
Low frequency response: -6 dB 25 Hz
Inputs: low level / high level
Outputs: low level / high level
Dimensions: 376 x 500 x 420 mm
Weight: 23 Kg
Features
- 180 W RMS output power for low distortion bass performance.
- 12″ Long throw heavy duty woofer for optimum bass impact.
- Dual flared rear firing ports for added bass weight.
- Internally braced cabinet for perfect support to the woofer.
- Bass extension to 25 Hz.
- Variable phase control.
- Variable remote controlled crossover frequency for perfect blend to any speaker system.
- Variable remote controlled volume for ease of setting bass level to your listening preferences.
- Auto power on/off.
- Compact size.
Power: 180 W
Weight: 23 Kg
