Πωλούνται SUBWOOFER TANNOY FX 5.1 και 2 δορυφορικά ηχεία
Πωλούνται SUBWOOFER TANNOY FX 5.1 και 2 από τα δορυφορικά ηχεία μαζί με βάσεις τοίχου
τιμή : 85 ευρώ όλα
τηλ 6976999447
Tannoy FX 5.1 Specifications
SATELLITES
Recommended Amplifier Power 15 - 100 Watt / 8Ω
Sensitivity 2.83 Volts @ 1m 87dB SPL
Frequency Response (-6 dB) 140Hz - 78kHz
Crossover Frequency 4.5kHz (mid to high) 140Hz (to subwoofer)
Dimensions 140 x 97 x 95mm (5 1/2 x 3 5/16 x 4 4/5")
Weight 1.83 lbs.
Low Frequency Driver
1 x 75mm (3") paper cone bass unit High Frequency Driver
1 x 15mm (5/8") Titanium dome neodymium magnet
Impedance 8 ohms
Magnetic Shielding Yes
Finish Silver
SUBWOOFER
Power Output 100W RMS
Frequency Response (-6dB) 45Hz - 140Hz
Dimensions 400 x 230 x 405mm (15 5/16 x 9 x 16")
Weight (each) 10kg (22lbs)
Driver Compliment 200mm (8") paper cone
Additional Features ON/OFF/AUTO power function
nikPIT
