ΡΑΔΙΟΕΝΙΣΧΥΤΗΣ AV SONY STR-DB1070 QS 6.1
6X100 W RMS EQ , CROSSOVER ΣΕ ΟΛΑ ΤΑ ΚΑΝΑΛΙΑ ΑΠΟ 40 ΗΖ - 140 ΗΖ, 6.1 PRE OUT, ΡΥΘΜΙΣΗ ΤΗΣ ΑΝΤΙΣΤΑΣΗΣ 4 & 8 OMS. 200 eyro thl.6974636336 Αλεξης
Power output:100 watts x 6 (8 ohms, RMS)Decoders:Dolby Digital 5.1 and 6.1, DTS 5.1 and 6.1, Dolby Pro LogicDSP modes:Virtual 6.1 (as well as the literal 6.1 mentioned above), 11 x cinema modes, 5 x virtual 3D modes, 10 x music modesVideo inputs & outputs:5 x video input (4 with S-video and composite, 1 with composite only), 2 x video output (1 with S-video and composite, 1 with composite only), composite and S-video monitor outputs, 1 x front mounted input with S-video, composite video and stereo audioAudio inputs:3 x optical input, 1 x coaxial input, 6 channel input, phono, 4 x line inputsSpeaker outputs:4mm banana plug/binding post for all six amplified outputsAudio outputs:2nd audio output, 6 channel pre outputs, 2 x line outputs, 1 x optical output, 1/4" headphone socket, Remote control:With full learning capabilities, control A1/A1ii socket connections, On screen display?YesDimensions WxHxD / Weight:430 x 161 x 401 / 13.2 kgSupplied accessories:Remote control, batteries, FM and AM antennasExtra:FM (RDS)/MW tuner built in with 30 random access presets and manual station name input, 96kHz/24 bit audio DACs for all channels, sleep timer
roberto_portale
