ΥΠΟΦΟΡΗΤΟ SONY VAIO VGN-TX1HP
L
LLLEFTERIS
Τιμουλα 700 ευρο
Δεν με ενδιαφερει καμια ανταλλαγη και δεν στελνω Επαρχια μονο απο Αθηνα!
Τηλ 6938811128 Λευτερης
Operating System Genuine Windows® XP Professional
Microsoft® Windows® XP Service Pack 3.0
CPU Section
Microprocessor Full Name Intel® Pentium® M processor Ultra Low Voltage 733400 MHz FSB, Supports Enhanced Intel SpeedStep® Technology
Microprocessor Manufacturer Intel
Microprocessor Speed (GHz) 1.10
Microprocessor Type Ultra Low Voltage Pentium M 733
L2 Cache (KB) 2048.0
Frontside Bus (MHz) 400.0
Memory
Memory Speed (MHz) 400.0
Memory Type DDR SDRAM (PC2-3200 DDR)(512MB on board, 1 slot free)
Max. Memory (MB) 1536.0
Memory Size (MB) 1024.0
Drives
Optical Drive Type Double Layer DVD±RW Drive
Hard Drive Capacity (GB) 60
Hard Drive Speed (rpm) 4200.0
Display Type X-black LCD with LED technology
Diagonal Size (in) 11.1
Resolution Format 1366 x 768
Resolution Type WXGA (16:9 ratio)
Graphic Card Full Name Intel Graphics Media Accelerator 900 with maximum 128MB Dynamic Video Memory shared with Main Memory
Producer Intel
RAM (MB) 128.0
Interfaces
4 Pin i.LINK™ (IEEE1394), 400 Mbps 1.0
DC in 1.0
Docking Station Interface 1.0
Headphone Jack 1.0
Memory Stick™ Slot 1.0
Memory Stick Slot Type Standard/Duo Size, Memory Stick Pro™, High-speed data transfer compatible, Magic Gate
Microphone Jack 1.0
RJ-11 Direct Port (Modem) 1.0
RJ-45 Direct Port (Network) 1.0
USB Speed High/Full/Low
USB Port (quantity) 2.0
USB Version 2.0
USB Connector Type A
VGA Connector for Monitor 1.0
PCMCIA Card Type I or II 1.0
Connectivity
Built-in Modem V92/V.90, K56 flex
Integrated Wireless LAN YES
Wireless LAN Max. Date Rate (Mbps) 54.0
Wireless LAN Range (m) 10 - 100
Integrated Bluetooth (Version) 2.0 + EDR
Bluetooth Range (m) 10
Bluetooth Max. Data Rate (kbps) 2100.0
Wireless LAN Type 802.11b/g
Ethernet network 100 BASE-TX/10 BASE-T
Multimedia
Built-in Stereo Speakers YES
Windows® Sound System Compatible YES
Keyboard Section
Touch Pad 1.0
Features
Auto Resolution Plug and Display
Dimensions
Depth Main Unit (mm) 195.1
Height Main Unit (mm) 21.0
Height Main Unit max. (mm) 28.5
Width Main Unit (mm) 272.4
Weight with Supplied Battery and Supplied Drive (kg) 1.25
Battery
Battery Type Lithium-Ion battery
Battery Charging Time (min) 210.0
Max. Battery Life (min) 465.0
Guarantee
Months 12
DAMBO
