- 2 Tannoy 605 με κάποια σπασίματα πλήρως λειτουργικα
- Specifications :
System Type...................................Ducted port
Terminals........................................Bi-wired
Drive Units.......................................2.5cm gold anodized aluminum tweeter
.......................................16.5cm bass unit
Peak Power.....................................150 watts per channel
Sensitivity........................................87dB/2.83V/1 meter
Crossover Frequency........................3kHz, first order high pass
Internal Volume................................10.5 liters
Recommend Amplifier Power............10 to 90 watts per channel
Frequency Response........................55Hz to 30kHz
Nominal Impedance..........................8 ohms (Minimum 6 ohms)
Dimensions(w x d x h)......................40 x 27.6 x 18.8 cm
Weight............................................7kg each
- Specifications :
- 2 Βασεις ηχείων δαπέδου σε αριστη κατασταση στα 20€
- 2 Βασεις ηχειων Vogels VLB200 σε αριστη κατασταση στα 20€
http://www.avsite.gr/forum/threads/set-Ηχείων-tannoy-611-605-crystal-audio-cs120.136721/
Brochure: http://www.hilberink.nl/tannoy2/tannoy_sixes_series.pdf
