κεντρικο ηχειο kef q95c
Πωλειται το κεντρικο ηχειο kef q95c σε πολυ καλη κατασταση.
Το εχω αχρησιμοποιητο γυρω στα 4 χρόνια λογο αδυναμιας τοποθετησης στο νεο μου σπιτι. Απο το καθεται ειπα επιτελους να το δωσω.
Το πουλαω €50
specs:
Q95C
KEF's reputation for centre channel speakers borders on legendary. The latest in the line is the Q95C which has the new clear-cone Uni-Q® driver for outstanding dialogue clarity and perfect timbre matching with the other models in the new Q Series.
Fourth generation Uni-Q® driver
160mm (61/2") bass unit with 19mm soft dome tweeter
Closed box design
Magnetically shielded for A/V use
Video grey finish
Q95C Specifications
Cabinet Design 2-way, 2-driver closed box
Crossover frequency 3.3kHz
Frequency Range +/ 3dB 85Hz - 20kHz
Sensitivity - 2.83v @ 1m 91dB
Maximum output - typical in room 111dB
Amplifier requirements 10-100W
Impedance 4 ohms
Weight 3.8kg (8.5lbs)
Dimensions
(H x W x D) 174 x 396 x 169mm
6.9 x 15.6 x 6.7in.
Finishes video grey
opanamas
