ρυθμιση av-sub
Eχω δυο μπροστινα heco με αυτα τα χαρακτηριστικα :
Gevoeligheid
89 dB
Impedantie
4-8 Ohm
Frequentie bereik
36-38000 Hz
Crossover-frequentie(s)
3500 kHz
ενα κεντρικο heco με αυτα τα χαρακτηριστικα :
Sensitivity
90 dB
Impedance
4-8 Ohms
The frequency range
35-38000 Hz
The crossover frequency
3.5 kHz
εναν πολυκαναλο με τις εξης επιλογες :
Press PHASE to switch the P.CTL (Phase Control) ON or
OFF.
Note
• Phase matching is a very important factor in achieving
proper sound reproduction. If two waveforms are ‘in phase’,
they crest and trough together, resulting in increased
amplitude, clarity and presence of the sound signal. If a
crest of a wave meets a trough, then the sound will be ‘out
of phase’ and an unreliable sound image will be produced.
• If your subwoofer has a phase control switch, set it to the
plus (+) sign (or 0°). However, the effect you can actually
feel when Phase Control is set to ON on this receiver
depends on the type of your subwoofer. Set your subwoofer
to maximize the effect. It is also recommended you try
changing the orientation or the place of your subwoofer.
• Set the built-in lowpass filter switch of your subwoofer to
OFF. If this cannot be done on your subwoofer, set the
cutoff frequency to a higher value.
• If the speaker distance is not properly set, you may not have
a maximized Phase Control effect.
(στο παρακατω οι επιλογες ειναι 50-80-100-150-200)
X.Over
• Default setting: 100Hz
This setting decides the cutoff between bass sounds playing
back from the speakers selected as LARGE, or the subwoofer,
and bass sounds playing back from those selected as SMALL.
It also decides where the cutoff will be for bass sounds in the
LFE channel.
και το παρακατω 12'' sub (σελιδα 11)
http://images.klipsch.com/KSW10Manual_635042115206260000.pdf
lowpass (hz)
40 εως 120
phase 0 η 180
Mπορει καποιος να μου πει τι ακριβως ρυθμισεις θα βαλω ? (υποθετω οτι θα δηλωθουν ολα small..? )
1.phase πολυκαναλου
on η οff ?
2.Hz πολυκαναλου (xover)
50-80-100-150-200 ?
3.phase sub
0 η 180 ?
4.hz sub
40.....120 ?
Eυχαριστω
Amp
Phase: Normal
Crossover: Small, 80Hz
Sub
Phase: Normal, εκτός της απίθανης περίπτωσης που μετά απο σωστή τοποθέτηση παίζει δυνατότερα με reverse phase.
Sub crossover: Τέρμα δεξιά, όπου κι αν είναι αυτό ώστε να μην επεμβαίνει.
opanamas
