τελικος ενισχυτης NAD silverline S 200
για δυνατους χρηστες,
αριστος, χωρις καθολου γρατζουνιες και χτυπηματα
πωλειται τιμη 850 ευρω.
δειτε και το link
http://www.ebay.co.uk/itm/320779288948?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
_______________________________________________________________
Specifications for the NAD S-200 amplifier
Continuous Output Power 1 225W (23.5dBW)
Rated distortion (THD 20Hz-20kHz) 0.03%
Clipping power (maximum continuous power per channel) 240W (23.5 dBW)
IHF dynamic headroom at 8 Ohms 1 dB
IHF dynamic power (Max short term pow./chan.) 8 ohms 280W (24.5dBW)
4 ohms 470W (26.7 dBW)
2 ohms 700W (28.4 dBW)
Slew rate >100 V/µsec
Damping factor (ref 8 ohms 50 Hz) >200
Input impendance 47kOhms / 700pF
Input sensitivity (for rated output into 8 ohms) 1.4V
Voltage gain x 28.3 (29dB)
Frequency response, 20Hz-20kHz 2Hz/100kHz (-3dB)
Signal/noise ratio ref. 1W 96dB
ref. rated power 120dB
THD + SMPTE I.M. + IHF I.M. <0.03%
Bridged (Monophonic) Mode
Continuous average power output into 8 ohms 1 780W (28.9 dBW)
IHF dynamic power (Max short term power/channel) 8 ohms 940W (29.7 dB)
4 ohms 1.3kW (31.1 dBW)
Physical Specifications
Dimensions(WxHxD) 17.73x7.09x15.56" 450x180x395mm
Απάντηση: τελικος ενισχυτης NAD silverline S 200
πουληθηκε, ευχαριστω για τη φιλοξενια
giorgos8907
