2 πολύμετρα ψηφιακά
pas2007
Πωλούνται 2 πολύμετρα σε άριστη κατάσταση.
1) ANENG AN8002 17€
Auto ranges
True RMS
550V protection in Resistance、Capacitance and Frequency ranges
Large LCD display,MAX display 6000 counts
Sample rate: 3 times per second
backlight
Data hold
Polarity identification
Low voltage indication
10A high current and low current measurement
Auto power off
Main measurements:AC/DC Voltage, AC/DC Current, Resistance,Capacitance,
Diode and Continuity Testing,Frequency and duty cycle.
* Frequency:1Hz to 10MHz
* Capacitance :10pF to 6000uF
* AC volts: 0.1mV to 750V
* DC volts:0.1mV to 1000V
* AC current:0.1uA to 10A
* DC current:0.1uA to 10A
* Resistance :0.1Ω to 60MΩ
* Duty cycle:1% to 99%
Specifications:
Capacitance :10nF(±5.0+20),100nF/1uF/10uF/100uF(±2.0%+5),1000uF/10000uF(±5.0%+5)
DC volts:600mV(±1.0%+10), 6V/60V/600V/1000V(±0.5%+3)
AC volts: 600mV(±3.0%+3),6V/60V/600V/750V(±1.0%+3)
DC current:600uA/6000uA(±1.5%+3),60mA/600mA(±1.5%+3),10A(±1.5%+3)
AC current:600uA/6000uA(±1.5%+3),60mA/600mA(±1.5%+3),10A(±1.5%+3)
Resistance :600Ω(±0.5%+3),6K/60K/600K/6M(±0.5%+2),60MΩ(±1.5%+3)
Frequency:5/50/500/5k/50k/500k/5M/10M (±0.1+3)
(9)Duty cycle:1% to 99%(±1%)
(10) Measurement mode: Double-integral style A/D transform
(11)Over range indication: OL
(12) Working environment: 0~40℃, relative humidity < 80%
(13) Supply power: 3V (1.5V AAA batteries * 2 Pcs)
2) ΠΟΛΥΜΕΤΡΟ AlloSUN EM-8903. 17,00€
RMAX: 20MΩ/KΛ 6 DCV MAX: 1000V/KΛ 5 ACV MAX: 750V
30€ και τα δύο
gvts
