Alpine Subwoofers
SWR-1541D
15" Subwoofer (4Ohm + 4Ohm)
Built from select materials and high-end components, designed for precision and efficiency, and protected by Thermal Management features — the Type-R subwoofers provide the kind of real power and massive bass only hinted at by other speakers.
Technical Details
Peak Power 1500W
• RMS Power 500W
• Frequency Response: 22Hz - 1kHz
• High Excursion 1-1/4" Santoprene Edge
• Kevlar Reinforced Pulp Cone
• Dual Progressive Nomex Spiders with Edge Control
• Integrated Tinsel Lead Spider Design
• Custom Cast Aluminium Frame with Integrated Heat Transfer Plate
• Extended Length Dual-Flared Vented Pole Design
• High-Strength Brass Voice Coil Bobbin
• Heavy-Duty 8ga.
Type-R Subwoofer Technology
kalelakos
