Amphony Wireless Audio Transmitter & Amp
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Amphony 5.8 GHz Wireless Audio Transmitter & Amps
Amphony unveiled its 5.8 GHz Digital Wireless Audio Transmitter / Amplifiers, Model 1520 and 1550, which are capable of transmitting audio to loudspeakers wireless and without any audio degradation.
Both wireless amplifiers connect directly to any regular passive loudspeakers, such as the surround speakers within home theater settings and eliminate speaker wires between the DVD player and the speakers. Each wireless amplifier receives a 5.8 GHz audio signal that is transmitted in a digital format up to 150 feet away from the transmitter. The technology provides true CD quality wireless audio at 5.8 GHz without any audio compression and is fully immune to interference from wireless devices using the 2.4 GHz frequency band. To minimize size and heat dissipation, Amphony incorporated digital class-T amplification, which provides the power efficiency of conventional class-D digital amplifiers at a far lower audio distortion. Each wireless amplifier only measures 5 x 3.5 x 2 inches and is easily mountable to a speaker. The Model 1550 is rated at 50-Watts peak output power per channel, 0.005 % audio distortion, 92 dB signal-to-noise ratio and provides a frequency response of 1 Hz to 23 kHz. The Model 1520 is rated at 20-Watts peak output power and 0.03 % audio distortion.
Amphony 1520 ReceiverThe 5.8 GHz Digital Wireless Audio Transmitter / Amplifier, Model 1520 set includes one stereo audio transmitter, which connects to either a line-level or an amplified speaker audio output and one wireless stereo amplifier. The set has a target street price of $129. The Model 1550 set includes one stereo transmitter and two wireless mono amplifiers and has a target street price of $199. Additional amplifiers can be purchased separately to operate from the initial transmitter.
Headquartered in Berlin, Germany, Amphony is a startup technology company that has become the leading provider of digital wireless headphones and audio transmitter products. Amphony specializes in the development of electronic products and technologies and is serving the consumer as well as the OEM market. In the U.S., Amphony products are sold by Amphony Corp., an affiliated Amphony company.
For more information, please contact www.amphony.com.
από το audioholics.com
Πολύ wireless κυκλοφορεί τώρα τελευταία στην αγορά.
Τελικά είναι τόσο αξιόπιστα όσο θέλουν να λένε?
Ή θα βγάζουν κάποιας μορφής "παράσιτο"
Δεν τα συμπαθώ ιδιαίτερα πάντως.
Προτιμώ τον πατροπαράδοτο τρόπο της...........μακαρονάδας!! :wink: :wink:
Αυτό φαίνεται καλό γιατί εκπέμπει στα άκρα του 802.11α.
Επομένως δεν θα υπάρχουν παρεμβολές από οτιδήποτε άλλο wireless κι επίσης να μην ξεχνάμε και τους φούρνους μικροκυμάτων... :wink:
Bandwidth έχει υπεραρκετό για μετάδοση ήχου (φτάνει και περισσεύει).
Αν έχουν χρησιμοποιηθεί και καλά υλικά θα είναι σούπερ :!: :D
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
αργά η γρήγορα τα wireless συστήματα θα κυριαρχήσουν στην αγορά (α,ρε καταραμένο waf). Ότι είναι πιο φιλικό στον μέσο χρήστη προωθείε από τις εταιρίες. Σε λίγο όλοι εμείς οι κάτοχοι των καλωδίων θα είμαστε οι ρομαντικοί της υπόθεσης. (η φιλικότητα προς τον χρήστη δεν συμβαδίζει πάντα με την ποιότητα)
Σίγουρα όμως είμαστε ακόμα στην αρχή της τεχνολογίας και σίγουρα θα υπάρξουν πιθανά προβλήματα, αλλά αυτά τα προϊόντα είναι το μέλλον...
Manosmathiou
