Aplus GV18 SMARTWATCH 1,54 ιντσες ,3G,παιρνει καρτα μνημης
paulk
πωλειται το συγκεκριμενο smartwatch ειναι αγορα 8 μηνων,αφορετο δεν με βολεψε λογω δουλειας ,,σε πολυ καλη κατασταση αγρατζουνιστο.Ειναι 3G παιρνει καρτα μνημης......Τιμη 20 ευρω......Τηλ. εποικεινωνιας 6994735470....Στελνω παντου
Τα χαρακτηριστηκα του
1.54 Inch Bluetooth 3.0 Wrist Watch hidden in the fashion design perfect full touch screen mobile phone
You can make calls,play music,can also exericise step gauge and so on
This GV18 wristwatch can be used as phone freestanding with SIM card
Ordinary Waterproof
Passometer, Sleep Tracker, Message Reminder, Call Reminder,Answer Call, Dial Call,Remote Control, Push Message
Specification
Appearance parameters:
1.Gewicht: 50g
2.Size:
(1) clock: 58.5mm x 39.5mm x 12.3mm (LxWxH)
(2) Strap: 78mm + 120mm
Hardware parameters:
1.Batterie: 450mAh polymer battery
2.CPU: 533MHz MTK6260A
3.Bluetooth 3.0 version
4.Bildschirm: 1.5 in TFT HD LCD, 240 x 240 pixels
5.Kamara: 1.3M
6.Speicher: 128M + 64M (support 32GB TF Card)
7.Verbindung: Bluetooth / NFC
Function:
1.Getting started simply mini smartphone.
The Sim card and Micro TF card can be inserted into the SmartWatch werden.Deshalb can SmartWatch as mini smartphone simply be used.
(1) Basic function: call, SMS, phonebook, alarm, calendar, Record, MP3 player, video player, going to the Internet.
(2) Language: interlingual language.
2.For Bluetooth Smart Watch.
(1) Show Time: There are different styles to show when you touch the screen.
(2) waterproof function.
(3) Pedometer: note the distance data.
(4) sleep monitoring: help you to increase the quality of sleep.
(5) sedentary Reminder: You can by this function to change some bad habit and improve your health.
(6) are reminiscent call.
(7) synchronously Function: SMS, phone book (after you connect the phone with the SmartWatch, you can send the SmartWatch data).
(8) Anti-Loss: The bracelet will remind you by the vibrator to the when the phone eliminator the bracelet over 10M.
(9) photo by remote control: convenient to photograph.
IMG_20191019_145513_1.jpg IMG_20191019_145522.jpg IMG_20191019_145532.jpg IMG_20191019_145622.jpg IMG_20191019_145513_1.jpg
paulk
πουληθηκε εκτος φορουμ παρακαλω να κλειδωθει,,ευχαριστω για την φιλοξενια
APOSTOLOS TSAPAS
