APS Klasik
m1ts0s
News poster
It is a no-compromise fusion of craftsmanship and sonic precision.
We have achieved this by obtaining a very smooth SPL amplitude and phase.
By using a very light, 19mm tweeter dome we managed not only to achieve great detail in the upper range of Klasik but also to provide excellent directional response.
Thanks to a 7 inch woofer sporting a very powerful and technologically advanced magnetic circuit Klasik offers a very precise and fast bass and mediums, very useful for precise EQ work.
Its active crossover was designed to the highest standard.
Each Klasik is carefully calibrated to the template and paired.
The incredible amount of work that went into Klasik puts it right next to some substantially more expensive products.
Technical specifications
Near-medium field monitor
TypeActive – two power amplifiers – AB class:
SystemTwo-way
Crossover Frequency3.2 kHz
DimensionsHeight x Width x Depth
32 cm ´ 21 cm ´ 28 cm/ 12.6’’ x 8.3’’ x 11’’
Free Field Frequency Response± 2 dB: 35 Hz ¸ 25 kHz
SPL in Free Field @ 1mRMS: 103 dB (single)
Peak: 111 dB (pair)
Weight8,5 kg / 19 lbs
Loudspeakers
Bass/Mid-Range LoudspeakerØ 18 cm (7’’)
Diaphragm: cellulose, surround: rubber
Tweeter loudspeakerØ 1.9 cm (3/4”) aluminium dome
(double magnet)
Amplifiers
Bass/Mid-Range Power Amplifier75 W RMS @ 8 W
Tweeter Power Amplifier75 W RMS @ 8 W
Total Harmonic Distortions0.005 % – PO = 5 W, f = 1 kHz
0.1 % max – PO = 0.1 up to 50 W, f = 20 Hz up to 20 kHz
Input Voltage Level for 96 dB SPL in Free Field @ 1m0 dBu (i.e. 0.775 V) – calibrated regulators in 0 dB positions
1000 ευρώ το ζεύγος
http://aps-company.com/en/products/klasik
Θάνος Γαλάνης
