Σε άριστη κατάσταση.
Ταχύτητα, διαύγεια, φυσικότητα.
https://www.aquahifi.com/la_voce.html
2600€.
Συζητήσιμη.
Νότια Προάστια Αθηνών.
Input:
- RJ45 AQlink (I2S serial bus) - PCM 24 bit / 384kHz – DSD64, DSD128 via DoP
- BNC coax (S/PDIF) 75 ohm - PCM 24 bit / 192kHz – DSD64 via DoP
- USB port - PCM 24 bit / 384kHz – DSD64, DSD128 via DoP
- MODULAR INPUT upgradeable, options:
- AES/EBU balanced 110 ohm - PCM 24 bit / 192kHz – DSD64 via DoP
- RCA coax (S/PDIF) 75 ohm - PCM 24 bit / 192kHz – DSD64 via DoP
- AT&T (ST Fiber) - PCM 24 bit / 192kHz – DSD64 via DoP
- Optical TOSLINK - PCM 24 bit / 96kHz
Proprietary USB Firmware / driver :
Apple MAC OS - Linux OS : USB asynchronous native support, no need to install drivers software
• Fully upgradeable asynchronous USB module with resolution 44.1kHz to 384kHz PCM up to 24 bits, DSD64, DSD128, operates with computers running OSX 10.7 and above, WINDOWS 10 , 8 , 7 and XP ASIO - WASAPI bit perfect high-speed
• AQ-i modular input: D111 XLR | D112 AT&T ST Fiber | D113 RCA | D114 TOSLINK with High Resolution platform
• Digital phase selector on front panel
2 separate low noise power transformers, one for the analog and one for the digital section
• MODULAR DESIGN with upgradeable multi board system
• Fully discrete analog stage, not even a single Op-Amp is used
2600€.
Συζητήσιμη.
Input:
