Ένα ηχείο χοάνης απο μια νέα ελληνική εταιρία βασισμένο στο AER MD3B
Iστοσελίδα.
Size: 220cmH * 100cmW * 90cmD
Weight: approx. 52 Kg
Frequency Response: 42-21.000 Hz
Max Power: 100W
Nominal Impedance: 16 Ohms
Sensitivity: 100db/1W/1m
The Pnoe speaker, being a large horn, is more suited to listening rooms with 3m or more distance between the listener and the speakers.
The standard internal wiring is the DNM Solid Core Precision and the binding posts are Eichmann Cable Pods. Both have been carefully chosen for the specific application.
Iστοσελίδα.
