NS S
Iintegral amplifier Audes NS stereo - in wooden case. Amplifier is developed specially for use with the loudspeakers Audes and first of all - Orpheus and Blues speakers. Amplifier Audes NS S has a unique design and the circuit, do not use a negative feedback and maximal output power in a result of 10 watt enough for comfortable transfer of any music through the speakers Audes in a room up to 40 square meters with the maximal quality of a sound.
Audes NS stereo
-integral amplifiers. They use EL34's in class "A"a Push-Pull Triode configuration without a negative feedback
and 6SN7 (6H8C) in driver. Has two inputs with a switch and high quality attenuators - preliminary amplifier is not necessary.
Output power - continuous 6Ohm: 15.0 W per channel.
Frequency response to 4 and 8 Ohm load., 20-20,000 Hz: +0.0/-1.0 dB
Signal to Noise, 10 W, CCIR/ARM: 100 dB
Sensitivity: 1.1 V
Input impedance: 63 KOhm
Loudspeaker output impedance: 1.6 Ohm
THD, 1 W, 1 KHz: 0.35 %
Power consumption 190 W
Dimensions: 46υ25υ38 cm
Weight: 18 kg
NS M
Audes serially lets out 2 models of amplifiers. Original monobloks Audes NS mono - in metal case. Amplifiers are developed specially for use with the loudspeakers Audes and first of all - Orpheus and Blues speakers. Amplifiers Audes NS have a unique design and the circuit, do not use a negative feedback and maximal output power in a result of 10 watt enough for comfortable transfer of any music through the speakers Audes in a room up to 40 square meters with the maximal quality of a sound.
Audes NS mono
- monoblock amplifiers.
They use EL34's in class "A"a Push-Pull Triode configuration without a negative feedback and 6SN7 (6H8C) in driver.
Output power - continuous 8/4Ohm: 4.0/6.0 W per channel.
Sensitivity: 1.0 V
Power consumption/channel 95 W
Dimensions: 34x24.1x32.1 cm
Weight: 15.5 kg
Three way, bass reflex system
Pyramid shape
Extremely rigid cabinet
Complex internal bracing structure
MDF based cabinet 25 mm thikness
Side panels used as an additional reinforcement as well as esthetical complement to a design concept using rare wood veneer.
Side firing woofer created to narrow front speaker panel.
Separate, isolated tweeter cabinet structure
MId-upper crossover enclosed in a separate, isolated chamber.
Audiophile, worlds best components
Specification:
Nominal impedance 6 Ohm
Recommended power 50 - 260 W
Frequency range (2 dB) 41/44* - 20000 Hz
Crossover frequency 150 Hz, 1800 Hz
Order in crossover network:
Low frequency 1st order
Mid frequency 1st and 3rd order
High frequency 3rd order
Sensitivity (2.83V / 1m) 87 dB
Lf corner (-6 dB) 34/38* Hz
Drivers:
10" paper-based woofer. Designed & manufactured by Audes
6,5" paper-based driver with phase correction system. Designed & manufactured by Audes
1" tweeter by SEAS.
Dimensions, (") 45x15x23
Dimensions, (mm) 1140x374x570
Weight 65 kg
DISTRIBUTORS:
http://www.audes.ee/index.php?id=1088
