AUDIOENGINE A5+ Ενεργό ηχείο Μαύρο ZEΥΓΟΣ + Audioengine D1 USB DAC
sps
Σε Άριστη Κατάσταση , στην συσκευασία τους.
Audioengine 5+
150W peak power total (50W RMS / 75W peak per channel), AES
Inputs
3.5mm stereo mini-jack, RCA L/R
Outputs
RCA variable line-out, USB (power/charge)
Input Voltages
115/240V, 50/60Hz manually switchable
Amplifier Type
Dual Class AB monolithic
Drivers
5" Kevlar woofers, 3/4" silk dome tweeters
SNR
>95dB (typical A-weighted)
THD+N
<0.05% at all power settings
Crosstalk
-50dB
Frequency response
50Hz-22kHz ±1.5dB
Input impedance
10K ohms unbalanced
Protection
Output current limiting, thermal over-temperature, power on/off transient protection, replaceable external main fuse
Dimensions (each speaker HWD)
Left - 10.75" (27cm) x 7" (18cm) x 9" (23cm)
Right - 10.75" (27cm) x 7" (18cm) x 7.75" (20cm)
Weight (LEFT speaker)
15.4 lbs (7 kg)
Weight (RIGHT speaker)
9.6 lbs (4.4 kg)
Shipping weight
31 lbs (14 kg)
Shipping box dims
15" (38cm) x 22" (56cm) x 11.5" (29cm)
Finish options
Satin Black
Hi-Gloss White
13mm thick MDF cabinets
3/4" silk dome tweeters with neodymium magnets
5" Kevlar woofers with advanced voice coils
Torroidal power transformer
D1 24-bit DAC
DAC type
Dual Mode USB and Optical (SPDIF)
Inputs
USB/Optical (SPDIF)
Outputs
RCA stereo/3.5mm headphone
D/A converter
AKM4396
Optical receiver
CS8416
USB controller
TI1020B
USB device class
Type 1.1 or above
Full-scale output
2.0V RMS
Output impedance
10 ohms
Power source
USB 5V
Power requirements
5V DC, 200mA
USB power filtering
2-stage redundant regulation
SNR
(DC to 20 kHz) >110dB
THD+N
(1kHz FS 96kS/s) <0.0025%
Crosstalkb
-85db
USB transfer mode
Asynchronous (dual clock)
Frequency response
10Hz - 25KHz (+/- 0.5dB)
Input bit depth
16 bit, 24 bit
Input sample rate (USB)
32kHz-96kHz - native playback
188.2kHz, 192kHz - re-sampled to 96kHz for playback
Input sample rate (optical)
32kHz-192kHz - native playback
Product dimensions
3.5x4x1"
Shipping weight
1.0lbs (0.5kg)
Τιμή 380 Ευρώ. Τηλ.6942980705
sps
Ευχαριστώ το AVSITE για την φιλοξενία και όλους για το ενδιαφέρον.
Τα ηχεία έφυγαν σε μέλος του φόρουμ.
Nikos67
