Features
Asynchronous transfer mode for USB input. (white paper)
Minimum phase digital filter. (white paper)
Single-pass 16x oversampling.
Zero feedback, fully balanced discrete circuitry.
Equilock circuitry for active gain devices.
Ayre Conditioner (patent pending) power-line RFI filter.
AyreLink communication system.
Specifications
Maximum Output Level
2.05 V rms – unbalanced outputs
4.10 V rms – balanced outputs
Frequency Response
DC - 20 kHz (44.1 kHz sample rate)
DC - 22 kHz (48 kHz sample rate)
DC - 40 kHz (88.2 kHz sample rate)
DC - 44 kHz (96 kHz sample rate)
Signal/Noise
110 dB (unweighted)
Input
1 USB, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz (up to 24 bits)
Dimensions
8.5" W x 11.5" D x 3" H 21.6 cm x 29 cm x 7.6 cm
Weight
5 pounds 2.25 kg
Πηγές:
Ayre
Tέστ στο Stereophile
Τιμή 2500$:108:
Πάντως λειτουργεί σε asynchronous mode και έχει μόνο μια usb ως είσοδο
