B&w Sub Asw650 Ametaxeiristo
ΤΟ ΠΑΡΑΠΑΝΩ SUB ΜΕ 5 ΠΕΡΙΠΟΥ ΩΡΕΣ ΛΕΙΤΟΥΡΓΙΑΣ ΣΤΗΝ ΜΙΣΗ ΤΙΜΗ.300 ΕΥΡΩ ΛΟΓΩ ΑΛΛΑΓΗΣ ΧΩΡΟΥ ΚΑΙ ΕΓΚΑΤΑΣΤΑΣΗΣ.ΕΙΝΑΙ ΑΓΟΡΑΣΜΕΝΟ ΠΡΙΝ ΑΠΟ 1 ΧΡΟΝΟ. 6978339463 Dimensions Height: 417mm (16.4 in) not including removable spike feet
Width: 415mm (16.3 in)
Depth: 495mm (19.5 in) including grille and controls
Allow extra 50mm (2 in) clearance at rear for ventilation
Net Weight 25.5kg / 56 lb
Freq. Response -3dB 25Hz – 33/150Hz adjustable (EQ at A)
Freq. Range -6dB 20Hz – 40/180Hz adjustable (EQ at A)
Drive Units Unit 1: 300mm (12 in) dia paper/Kevlar® cone long-throw
Unit 2:
Unit 3:
Finish Cabinet: Black Ash or Sorrento (light oak) vinyl
Grille: Black Cloth
Sub Woofer Amplifier Description: Class B
Power Output: 200W continuous
Rated Power Consumption: 280W
Input Impedance: 22k ohms
Signal Noise: 90dB
Functions: Volume level - Low-pass filter frequency - Low-pass filter bypass - Bass roll-off alignment - Phase 0/180 - Auto sense on/standby
Inputs: Line In (RCA Phono)
Speaker Level In (binding posts)
Outputs: Line Out (RCA Phono, high-passed)
Link Out (RCA Phono, parallel to Line In)
Speaker Level Out (binding posts, high-passed)
Low Pass Filter Active 2nd-order, variable cut-off frequency
High Pass Filter Line level: Active 3rd-order at 80 Hz
Speaker Level: Passive 1st-order at 80Hz into 8 ohm resistor
(Response of passive filters dependent on load impedance)
xkaragi
