m1ts0s
News poster
Adaptable acoustics
A powerful five-driver set up delivers immersive, full-range sound that adapts based on the speaker's orientation. Discover dynamic bass when laid flat, unmatched clarity when upright or an enveloping soundstage when wall mounted. Active room compensation enables Beosound Level to adapt audio quality to complement any space – whether big, small, busy or sparse. The result: a clear, detailed listening experience at all times.
Compact and perfectly portable
With a minimalist, Scandinavian-inspired design, Beosound Level has been created with aesthetics, practicality and durability at its core. A smoothly integrated handle ensures easy pick up while IP54 dust and splash resistance means you can place it anywhere with confidence. With up to 16 hours of battery life, this elegant speaker is designed to enhance whichever room it's moved to.
Recommended Room Size
10-50 m² 100-500 ft²
Speaker Configuration
2 x 4” woofer drivers 1 x 2” full range drivers 2 x 0.8” tweeter
Amplifier
2 × 30 W class D for woofer 1 × 30 W class D for full range 1 × 15 W class D for tweeter
Frequency Range
39 - 23000 Hz
Maximum Loudness @1m (SPL)
96 dB SPL
Bass Capability
79 dB
Stereo Pairing
Pair two Beosound Level to enjoy a stereo listening experience. Set up the stereo pairing through the Google Home App.
Advanced Sound Features
Active Room Compensation Adaptive Bass Linearization Position-depended sound staging Thermal Protection
Customizable Sound EQ
Presets available and fully customisable through Bang & Olufsen App
From €1,249
https://www.bang-olufsen.com/en/speakers/beosound-level
Amplifier
Frequency Range
39 - 23000 Hz
96 dB SPL
Bass Capability
79 dB
Stereo Pairing
From €1,249
