Χρήστος Ακρατόπουλος
Exclusive Senseye Technology
For fine-tuned, true-to-life images. By optimizing color, clarity, motion and contrast, Senseye technology produces vivid, true-to-life images that are distinctly deeper, richer and clearer.
Independent Four-Color Adjustment
Independent Four-Color Adjustment (red/green/blue/yellow) gives consumers more control over color adjustment, to suit each person's individual preferences, without causing aberration.
DCDi video processing for crisp, clear images.
With Directional Correlational Deinterlacing (DCDi), video is analyzed pixel by pixel to detect the presence or absence of angled lines and edges, which are then processed to produce a purer and more natural looking image without visible artifacts or jagged edges. In this way the BenQ DV3750 makes moving images look smoother and more natural.
High Quality Display
With its high-quality 1920 x 1080 digital specifications, the DV3750 displays extremely delicate images and is HDTV 1080 resolution compatible. The fine image provides you the sensation of watching true-to-life image.
- 8ms Gray-to-Gray Response Time: Equipped with an ultra-fast 8ms gray-to-gray response time, the DV3750 delivers smooth images with no lagging.
- 800:1 Ultra-High Contrast Ratio & 176° Wide Viewing Angle: With its 800:1 contrast ratio, the DV3750 processes bright and dark images more precisely, so that you can see every detail even in the darkest images. Because of the extreme viewing angle, you can enjoy a clear, precise and vibrant image from absolutely anywhere in the room.
Enhanced Surround Effect
SRS TruSurround XT technology and Virtual Dolby Surround Prologic II enable you to enjoy the full experience of 5.1 channel surround sound with just a two-speaker audio system.
TruSurround XT technology also features a patterned cinema-like bass resonance technology and allows the dialogue voice to be centralized, making it easier for the sounds to be heard.
LCD Size 37 inch / 94 cm
Aspect Ratio 16:9 (Wide Screen)
Resolution (max.) 1920 x 1080
Brightness 550 cd/m2
Contrast 800 : 1
Viewing angle (L/R;U/D) (CR>=10) 176 / 176
Response time (tr/tf) 8 ms Grey to Grey
Video Compatibility PAL / NTSC
Input Connections
Terminals
Composite AV (2)
2 S-Video + Audio
Component (Y Pb Pr / Y Cb Cr) + Audio (2)
D-Sub
PC Audio
DVI-HDCP + Audio
RS232
Speaker 15W x 2
Features
Senseye Technology
Motion Adaptive De-Interlacing
10 bit color processing
RGBY 4 colors independent adjustment
3D Y/C Comb Filter
Picture In Picture / Picture By Picture
Picture Freeze
Backlight Eco Mode
Color Temperature (Warm/Cool/Standard)
Sleep Timer
Dimensions (HxWxD)
With Stand (HxWxD)
1025x657x220 mm
Without Stand (HxWxD)
1025x591x122 mm
Weight
With Stand
23.5 Kg
Without Stand
20.7 Kg
Power supply 230W, AC 100~240V, 50/60 Hz
Ρώτησα την BSI αντιπρόσωπο της BENQ στην Ελλάδα και μου είπαν ότι έχουν ένα πρόβλημα με τις εγγυήσεις και γι' αυτό δεν τις έχουν φέρει ακόμα στην Ελλάδα....
