120 ευρω
Beresford TC-7220 MKIII Μηχανικό Switcher
Αθήνα.
Swapping amps and speakers The TC-7220 MKIII is a compact selector that offers selection of the audio signal between up to two amplifiers and two pairs of speakers. Alternatively, it can be used in Bi-Wire mode so that it can connect any of two amplifiers to a pair of speakers capable of accepting bi-wiring. The sources and outputs can be selected via two sets of push buttons on the front of the box. Speakers and amplifiers connection are va standard banana plugs or spade terminals. Ideal for multiple audio sources such as a stereo amplifier av AV amplifier. Designed to provide distortion free audio from your audio amplifier or Home Theatre System, to your speaker. NEW mkIII Evolution (2018): Better back connectors More space within the connectors to allow handy installation and the use of thick cables/bananas/spades. Better protection against the short circuits Multi Bi-Wire option The TC-7220 MKIII is the only audio router on the market that includes a Bi-Wire option. The clear and simple bi-wiring arrangement is also a world's first, giving you a chance to try this mode if your speakers are provided with Bi-Wire input terminals. Possible applications Select between two audio amplifiers and a single pair of speakers Select between one audio amplifier and two pair of speakers Select between two audio amplifiers and a pair of speakers that are Bi-Wire ready Select one pair of speakers between an audio amplifier or a 5.1 r 7.1 DSP or AV amplifier
Αθήνα.
112,7 KB Προβολές: 0
440 KB Προβολές: 0
515,6 KB Προβολές: 0
842,5 KB Προβολές: 0
